02-26-2004, 09:56 PM
Car: 318iS
URGENT- swapping suspension
can anyone help me here? I have to swap the springs off one e36 to mine. Problem is we dont have a shop to do it.
Can anyone point me in the direction of a tutorial on how to swap them? Also, can anyone tell me which tools ill need to do it?
this is urgent since i must know before saturday morning!!
thank you!!
>>www.revscene.net<<
02-27-2004, 01:37 AM
BMW Traitor
Car: AMG, M, R, Aero
Re: URGENT- swapping suspension
thank you!!
Everything is quite straight forward, but you'll need a spring compressor tool to compress the front springs.
The rest all you will require is a socket wrench and a set of sockets. A good 2 tonne jack and 2 jack stands should be fine.
If you're planning on swapping any springs from a 6 cyl into a 318 using the 318 strut, it won't fit. Just be warned.
Bry
02-27-2004, 06:30 AM
Car: 318iS
thanks, its just 318 to 318 though. phew
>>www.revscene.net<<
02-27-2004, 06:34 AM
moderationistismingly
Car: 97 328is-02 Impreza
For the rear springs, it's recommended that you unbolt the half shafts from the diff to prevent damaging the CV joints. You'll need a torx socket for this, I forget what size.
Also, get a friend to help, you'll need and extra set of hands.
