02-02-2004, 07:33 PM
Car: 1984 318i, 1974 Super V-DUB
speedometer
the other day my speedometer stopped working completely. every once in a while it will bounce a little but it wont read i checked the sensor on the differential and there is no power getting to it i dont know what is wrong any suggestions ? p.s. the car is an 84' 318i thanx in avanced
02-02-2004, 08:15 PM
twisted beyond reason
Car: e46/ and ??
When my gauges stopped working it was the batteries in the cluster itself. they usually die after 10-15 years
02-02-2004, 09:28 PM
Car: E30, 318i, 84 (project restoration)
aahhhhhhh good old '84 318 up to their old tricks again...
Mad E30 lover
02-03-2004, 01:46 AM
Car: 1984 318i
so if change the batteries it should start working ? everything else works just not the speedo?
02-03-2004, 02:29 AM
Car: Probe GT...
if the odometer isnt adding up, dont worry bout it
just estimate your speed
02-03-2004, 03:23 AM
yeah its just the speedo everything else works, i think its effecting the mpg gauge and the odometer because the mpg gauge moves around all the time for no reason and the odometer hasn't changed milage thanx for the feedback.
02-03-2004, 03:29 AM
hey i have another question, iv read my manual but it dosn't tell were the batteries are located or what type they are wondering if any one can help me thanx
02-03-2004, 04:54 AM
dodging pylons
Car: e30 318i , e36 325i
how about this one.........
my speedo works always,
my gas gauge only has the light come on when its empty
my temp works once it gets to midway point
and my tach works when it feels like it
good old 84 318i!
edit: my odometer stopped about 5 years ago too
02-03-2004, 02:14 PM
Guest
if it was just a blown fuse than you would most likely have more than one thing out rite now, ont just the speedo/odometer
It may just be a bad connection if it is only your speedo that is out
pop the cluster out and check for a loose connection
02-03-2004, 02:53 PM
#10
i looked at all the connections and didnt find anything loose so i thought maybe the wire was cut i was just going to run a new wire but there are two wires of the sensor and only one on the speedo.
02-04-2004, 12:00 AM
#11
christian while your back there you might want change out your bulbs for new ones, save you time later.
what kind of battery is this? can i get it from BMW dealers? bulbs too? some of you might his of the dealer question as stupid but dealers don't keep up with the old stuff after a while.
oh yeah my odometer is dead too; is this fixable?
Mad E30 lover
02-04-2004, 04:25 PM
#12
went to a BMW dealer near me hopping to get a batteries for my cluster. Told me batteries and board come together not seperate. Price $200.60? This board better be new or very important for $200, since I must pay out of my pocket....
Mad E30 lover
02-06-2004, 01:42 AM
#13
oh yeah forgot to add the board may not be nessary if the rest of your gauges work, there is a follow through method to fix this problem...
Mad E30 lover
02-06-2004, 09:41 PM
#14
Car: 318i
Dont buy a new board, and you dont need new batteries either.
Check out this article I had the exact same problem, and tried re-soldering the speedo. It wasnt hard to do at all, and has worked fine for 3 years!
Axis Springs
HK2 Intake
500 watt Legacy amp
Two 10 inch JLA's in the trunk
02-08-2004, 05:46 AM
#15
Car: e30 318i
just had this prob last month everything in my car worked fine then my speedo started going crazy turns out my alternator was fried got a new one and walla
1995 VOLVO 850 Turbo
1986 Chev Camaro Z28 running 250 horse with just a stock motor and open air filter carbed.
allcanadianreject84@hotmail.com
