02-04-2004, 01:23 AM
#1
Car: 01 540i M-6pd
Back Brake Lights
My back brake light keeps goig out on the right side  and the thing is everytime i fix it, it eventually goes out again! anybody have the same problem or have any advice on how to fix this problem?
Thanx in advance
TiMe Is NeVer WaSteD WheN YouR WaSTEd All The TiMe
01 540i-M 6spd
02-04-2004, 01:25 AM
#2
7th Gear Member
Car: 335I
ive had that prob... i went to pitstop and they fixed it... it jsut had no contact or something like that...took them 1 min to fix it (I think they cleaned it or something)
02-04-2004, 02:30 PM
#3
Car: 01 540i M-6pd
Yeah, that's what i was told. what's the best way of cleanign the contact on it?
01 540i-M 6spd
02-04-2004, 02:51 PM
#4
BMW again.
Car: 1994 325is
a bad contact is a very common reason for a fault on our tailights. check the contacts , clean them if you can and you should be ok.
02-04-2004, 04:21 PM
#5
BMW Traitor
Car: AMG, M, R, Aero
The best way to to clean contacts would be to get some sandpaper or use a file and just sand down the contacts of both the bulb and the metal contact of the lens.
Bry
'02 Mercedes C32 AMG 3.2L Supercharged @ 18psi - 341WHP/358lbs*ft TRQ (DynaPak) Eurocharged custom tune, ASP 178mm crank pulley + PSK, CM30 i/c pump, i/c iso kit, Magnecore wires, NW CAI, dual custom exhaust, H&R sway bars, H&R SS coilovers, KMAC camber kit, H&R spacers, Quaife ATB LSD, goodridge SS lines, Porterfield RS4 pads, AMG 18" rims, AEM UEGO wideband, Dashdaq datalogger, Kenwood Excelon DNX8120
02-04-2004, 10:08 PM
#6
///MMMM VIDA
Car: E36 325iS
bend them out a little too....thats what happened to me...they weren't making proper contact
UNDER CONSTRUCTION
02-05-2004, 12:35 AM
#7
Car: e36 m42
bend them.. sanding is good too... contact cleaner.. (buy from radio shack.. around $5 for a can) when you're done...
I had an aftermarket tail light that kept blowing a fuse... turned out the fixture itself was not seated totally flush and causing a short somewhere... very weird. you using aftermarket tails?
02-05-2004, 12:53 AM
#8
Car: 01 540i M-6pd
Dunno man, just bought the car littl eover a week ago, how can i tell?
01 540i-M 6spd
02-06-2004, 02:06 AM
#9
///MMMM VIDA
Car: E36 325iS
does it have a orange turn signal
UNDER CONSTRUCTION
02-06-2004, 02:18 AM
#10
Car: 01 540i M-6pd
yup, they're the original lights
01 540i-M 6spd
02-06-2004, 04:14 AM
#11
Car: Wolfsburg Golf 2011
i had that problem once for weeks final solution permanent fix was solder a longer contact on the socket where the bulb goes in ... and that fixed the problem for good ...
Pedal To The Metal
