Old 12-26-2003, 06:05 PM   #1
85eta
85eta's Avatar
Send a message via MSN to 85eta
e30 brake rotors
If I were looking to buy front and rear rotors for my e30. What price would I be looking at per rotor? And in your opinions, is it worth it to buy cross drilled or slotted rotors?
85eta is offline   Reply With Quote
Old 12-27-2003, 02:55 AM   #2
M50E30
www.bmwclub.ca
M50E30's Avatar
I would suggest Power Slot rotors all around. Not as harsh on your pads as X-drilled...besides drilled rotors have less pad to rotor contact.
I sell them at my work for your car:
FRONT: $93.86+tx/each
REAR: $87.05+tx/each
I also sell Power Stop (X-drilled) front rotors only but they are about $120+tx/each. But I don't like them.
M50E30 is offline   Reply With Quote
Old 12-27-2003, 03:01 AM   #3
Slowered318
Slowered318's Avatar
Stock Rotors are just as good as the drilled or slotted.. sometimes better!
Go with ATE
The pads are more important then the rotors.. and most of all your calipers must be in excellent working condition
Don't forget to bleed the breaks completely.. i just got a bavauto break bleeder if you need to borrow it.
Old 12-27-2003, 03:09 AM   #4
M50E30
www.bmwclub.ca
M50E30's Avatar
Ryan,
You should also add stainless steel braided brake lines as a good upgrade compared to the stock lines.
Dave
Old 12-27-2003, 03:10 AM   #5
Slowered318
Originally posted by M50E30
Ryan,
Dave
For shure.. a MUST have!
Old 12-27-2003, 05:47 AM   #6
85eta
85eta's Avatar
Thanks guys
Old 12-27-2003, 09:00 PM   #7
NickP
NickP's Avatar
You can find brembo rotors for around 110 front and 85 rear... this place custom drills the rotors for alittle more.
I say you stick to stock unless you like the looks.
NickP is offline   Reply With Quote
Old 12-27-2003, 10:48 PM   #8
huh? Does stainless steel braided brake lines improve braking?
Dare I squeeze
Old 12-28-2003, 03:29 AM   #9
85eta
85eta's Avatar
ok another question.....is there anyway to tell if I need new rotors, other than I suppose just measuring the thickness? My brakes have always worked perfectly, I guess I just take them for granted. I do have new ( almost new ) pads in the front and rear. They also never shake and don't make any noise.
Won't rotors start to warp when they get too thin because they don't dissapate the heat as well?
Old 12-28-2003, 06:59 AM   #10
Jon@Bimmersport
Jon@Bimmersport's Avatar
my brakes squeek....but braking is good. wtf does this mean?
Authorized Ontario dealer for Active Autowerke|VF-Engineering|AFE|Bilstein Suspension|H&R Suspension|KW suspension|Brembo Brake Systems| Stoptech| - Call us for the best pricing
Old 12-28-2003, 07:33 AM   #11
ZiMMie
Send a message via ICQ to ZiMMie Send a message via MSN to ZiMMie
chk ur rotors. i have the same problem thought it was the brake pad chaged it and it still squeek lke a bitch.
www.StanceFactory.com
Old 01-21-2004, 06:11 PM   #12
mirek
mirek's Avatar
I have the same problem, it squeeks, not all the time, but usually. replaced the rotors, stopped squeeking for a while.
I think i'm going to have to replace my pads and if that doesn't fix it, lube up my calipers.
