Old 12-15-2003, 07:30 PM   #1
Autotechnica
Little Chino
E36 sway bar specs please..
I need the sway bar diammeter specifications for the E36 318i and the E36 M3. Also, are there any differences in diammeters for different year M3's?
I'm swapping M3 sways into my 318.
Thanks,
Bryan
Old 12-16-2003, 03:11 AM   #2
thinair
moderationistismingly
thinair's Avatar
you can swap M3 sways into your 318i, but remember they mount differently on the front of the M3 as you know (to the struts). Which means (from what I've been told) that an M3 can get by with a thinner front bar.
Old 12-16-2003, 04:12 AM   #3
Autotechnica
Little Chino
The rear M3 sway bar will fit the 318, but the front will not. I've purchased a conversion kit from Ground Control which consists of 2 brackets which must be welded on inorder to fit the front sway bar. Shouldn't be too much work I hope.
So are you saying that the front 318 sway bar is thicker than the front M3 sway bar?
Thanks,
Bryan
Old 12-16-2003, 10:04 AM   #4
thinair
thinair's Avatar
No, because I don't know the exact thickness
Old 12-16-2003, 04:53 PM   #5
325iSBimmer
///MMMM VIDA
325iSBimmer's Avatar
i've heard about what ur talking about... i think they are thinner but since they mount to a different spot they will still stiffen up the sway of the car.
UNDER CONSTRUCTION
Old 12-16-2003, 05:36 PM   #6
KIRASIR
Your Nightmare
KIRASIR's Avatar
stock M3s
- 95 front is about 22.5mm
- 96+ front is about 23mm
318/318ti/325/328
varies from 24-26mm.( not sure about very early 92 models)
The average non-M3 front sway bar size is about 25mm.
SL
Old 12-16-2003, 07:25 PM   #7
Autotechnica
Little Chino
Thanks Serge, do you have specs for the rear bars as well?
Do you think I should keep my stock front sway bar and just swap the rear with the M3 bar or do the whole conversion?
Thanks,
Bryan
Old 12-16-2003, 07:38 PM   #8
KIRASIR
Your Nightmare
KIRASIR's Avatar
http://www.uucmotorwerks.com/html_pr...escription.htm
I don't remember the size for the rear of the regualar 3-series. I only remember the 318ti size which is totally different.
In my opinion, you cannot beat the adjustability of the aftermarket sways like RD or Eibach. So I wouldn't even bother with getting M3 sway bars.
SL
Thanks,
Bryan
Old 12-16-2003, 08:00 PM   #9
Autotechnica
Little Chino
Say if I paid $100 for the sway bars and the brackets, would you think there would be an improvement? Aftermarket bars can cost $600+CDN, that's a pretty huge difference in price.
thanks,
Bry
Old 12-16-2003, 08:03 PM   #10
KIRASIR
Your Nightmare
KIRASIR's Avatar
You will definitely see an improvement over the stock bars(assuming you connect the front to the struts). If you want to have more control with things like track/autocross setup then spend the money and get aftermarket sways.
SL
thanks,
Bry
Old 12-16-2003, 08:08 PM   #11
Autotechnica
Little Chino
ok finally found the info.
96+ M3 front rear
0.905" 0.787"
318 front rear
1.0" 0.75"
This is what I found on some no name website. If anyone knows this info is incorrect please post the right diameters.
Thanks!
Bryan
Old 12-16-2003, 08:36 PM   #12
Jon@Bimmersport
Jon@Bimmersport's Avatar
why not check with the dealer? would they know? or email turner motorsport or somethin
