Old 08-22-2003, 07:26 PM   #16
SickFinga
SickFinga's Avatar
It is not a traction control light.
It is worn out brake pads light.
phaust, no you only need 2 sensors.
BMW has brake sensors on the left front nd rear right wheels.
Old 08-22-2003, 07:37 PM   #17
Adriano
Who's your daddy now?
Adriano's Avatar
Send a message via MSN to Adriano
If you look at the sensor it looks like a half circle pointing twards the inside of the lining. If that semi-circle is worn off the sensor then you will have to change the sensor. If you havent used your brakes too much since the light came on, then you can reuse the sensor.
Agent BMW trailer
Adriano is offline   Reply With Quote
Old 08-23-2003, 06:13 PM   #18
phaust
thanks all for your reply! now i will be able to check this out!
btw. somebody have a CD of the manual or any material about a 325is 1995, like i saw at the garage... it's like a 3d view of your car, with all parts number...
thanks!
phaust is offline   Reply With Quote
