Old 07-15-2003, 03:38 AM   #1
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Sub recomendations.
Here are my 2 options.
Build a Custom set up for my 2 current 10's (MTX Thunder 4000s switch from bandpass to sealed and port it into my cabin). I already have most of it planned out.
OR
Sell my 10's and Boxes and get one 12. Ive got a pioneer 600w amp which RMS would run at 300watts at a 4ohm Load. So Id be looking for a sub thats numbers are around tha much.
I am kinda looking at:
Rockford Fostage Punch He's: http://www.sounddomain.com/sku/ROCRFP4812
Infinty Reference:
http://www.sounddomain.com/sku/INFREF1230W
JL W3
I want more SQ than my current setupu provides with just a decent amount of thump.
Any other recomendatons?
With the 12" or 10" setup the subs would be more or less right in the ski hole.
Stanceiseverything.com
Old 07-15-2003, 03:47 AM   #2
Soldo
Soldo's Avatar
if you want CLEARER sound stick with 10's, 12's are made more for bass!!
Keven Soldo
Old 07-15-2003, 03:54 AM   #3
Slowered318
For your car i would recomend one 12 in a costom built 4th order bandpass ported through the ski boot. I wouldn't use any of that equipment excpt maybe the JL's. It's not an easy box to build the right way but if you can come up with some coin PM me and i'll hook you up with a shop that will do it right.
Old 07-15-2003, 04:09 AM   #4
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
How about MB Quarts subs... can I get em here?
How much would the box cost? I have some bread..
Old 07-15-2003, 10:42 AM   #5
Jon@Bimmersport
Jon@Bimmersport's Avatar
dave...dont make the same mistake zee did..tell me all the parts u want and ill get u a price...thats cheaper than 90% of every place out there!
Old 07-15-2003, 12:46 PM   #6
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Jon I am gonna go through you most likley.
Im just looking for what sub to do. I want the box made for my sub and for my trunk.
Old 07-15-2003, 11:33 PM   #7
///MAGAKS
///MAGAKS's Avatar
Send a message via MSN to ///MAGAKS
Sell the MTX and get Clarion or Eclipse Subs there good
///MAGAKS is offline   Reply With Quote
Old 07-17-2003, 01:07 AM   #8
Adriano
Who's your daddy now?
Adriano's Avatar
Send a message via MSN to Adriano
Sorry buddy but that is probably the BIGGEST MISCONCEPTION ever in car audio.
Size of the sub has little to nothing to do with how "clear" the sound is! The rule of thumb is put the biggest sub in possible with the size restrictions on the enclosure. Bigger subs generally can reproduce lower frequencies and at a higher SPL than smaller subs. If you want a tighter sound (cleaner??) then you can adjust your ports/box volume/crossover/eq. I'm not trying to be an ahole but I can't tell you the number of times that I have corected people about this.
Agent BMW trailer
Adriano is offline   Reply With Quote
Old 07-17-2003, 03:41 AM   #9
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Adrino what do u recomend? For a 300rms 4ohm sub.
Old 07-17-2003, 04:14 AM   #10
///deni-boy///
///deni-boy///'s Avatar
A lot of ppl think the biggger the sub the better, my friend wants 4 15's in his car, but he doesnt understand that if you dont have the right box, the speakers wont perform the way they can, its all about the box you use and the size of it, i'm making some custom speakers for home use, but the place that i got them from gave me a booklet on how to make all kinds of speakers, what kind of insolators to use on the inside of the box, and stuff like that.
The Speaker Shop
Frank Fabian (custom speaker specialist)
1578 Eglington Ave W. Toronto
(416) 782 - 4451
Just talk to this guy or someone who works there, they know a lot and ask them any questions u have and they will give you suggestions, u dont need to buy anything, just ask, they have pretty good prices too.
///deni-boy/// is offline   Reply With Quote
Old 07-17-2003, 05:51 AM   #11
Gamite
Gamite's Avatar
I have dual 12's but with a sealed box, the sounds is actually quite tight. I've gone the route of SQ rather than SPL.
I'd probably pick JL's as a company to go on. I like Slowered's suggestion, the single 12.
www.gamite.net
Old 07-17-2003, 01:15 PM   #12
Adriano
Adriano's Avatar
Again, as I said before, the size restriction is your box volume that you can physically fit into your car. You will also need to know what configuration will be your box-bass reflex, ported reflex, or bandpass. Again, the bigger, the better. It's liking buying an 328 or 318. You may not need the extra power from the 328 but it is nice to have and there is no downside (other than gas consumption-not applicable to subs). You have to decide on what kind of music you listen to. Rap, dance, country, jaz? This will determine at what frequency to tune your box and the overall design of the enclosure. I went with 2-12"s ported thru the back deck. I am using MTX T8000 with two 3.5" x 18" ports and a total of 3.15cu in enclosure. There is 2" of fiberglass on 3 interior walls of the box. This design can be used for SQ and SPL competition. If you have the money and room, SIZE DOES MATTER! As far as manufacter, it's like comparing GM to Ford. You want to find the right sub for the application. I usually purchase the sub to fit the application not the other way around.
Agent BMW trailer
Old 07-18-2003, 06:24 PM   #13
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Well I think Im gettin the W3.
I listen to mostly rap and hip hop.
I made my new trunk set up outta cardboard today. So I have the templates just waiting on a pay cheque.
Old 07-30-2003, 07:14 PM   #14
JOE325E
I have 2 Audiobahn awq1006's (flame q's) Wired parallel with a sony 1000w amp in my wifes mustang, Damn if they don't rattle your teeth. They sit in a 2.75 cuft box firing towards the back of the trunk. My brother has JL W3 in the 10 in variety and the same amp and the same model mustang and they don't compare, my audiobahn's lay waste to the JL's. But that is my opinion. My brother was so impressed he went down and bought audiobahns the same day.
JOE325E is offline   Reply With Quote
Old 08-02-2003, 12:29 PM   #15
notjoe
600rwhp here i come
notjoe's Avatar
Send a message via ICQ to notjoe
Could they do the same thing with a Kicker L7 12" ?
notjoe is offline   Reply With Quote
