Old 08-08-2014, 10:56 AM   #16
Woofer
Woofer's Avatar
It's a great idea lol. Shouldn't cost you more then 400 for 2 months of storage. Mine even has power. If you want more info pm me. I'd be glad to help. uploadfromtaptalk1407509734059.jpg
Old 08-09-2014, 07:49 AM   #17
325isdan
Why do you want to go M52 instead of S52?
Old 08-09-2014, 09:10 AM   #18
partner103
Mostly because of the $$$ involved. S52 as far as I could see the pricing is a bit more steep vs. an M52.
partner103 is offline   Reply With Quote
Old 08-10-2014, 09:00 AM   #19
325isdan
I would just a save a little longer then. Complete S5x swaps are going for less then 3gs. The swap is going to cost the same regardless of the motor.
Old 08-11-2014, 09:47 AM   #20
partner103
True, but the cost of the M52 is much less then 3gs. That's more my price range.
Being a family man (father and all) I have to consider that factor.
Plus I think I'd be happy with the M52 as well.
Old 08-11-2014, 05:43 PM   #21
325isdan
What motor do you have now? Might as well just go turbo and like under 10 psi.
Old 08-11-2014, 06:38 PM   #22
partner103
318i completely stock this type of performance wise. Diff, motor (M42), brakes, tranny, ECU etc.
See, I actually thought about M52 then turbo charge that. Don't know much about the motor in terms of prepping it for turbo. But I figured if the cams, pistons, injectors etc require work, I rather do something like that on an M52 (with less mileage) than on the M42 I have currently, pushing 255 kms.
What would I have to up motor wise on an M42 so it doesn't give up in a year?
I mean look at a snipped from someone's list on R3V.
Forged CP pistons 8.5:1, Stainless rings. 85 mm overbore
Balanced bottom end
360 degree oil well bearings
Stock head gasket
Full ARP fastening hardware (connecting rod bolts, main studs and head studs)
I don't even know what and why on some of these....
Anyone else feel free to chime in.
Discussion seems to have taken a turn to a more interesting topic. (still need a good shop though )
On a related note, this is what you get http://www.youtube.com/watch?v=F9FMbcrtomw
with this
1991 318is e30 with Mitsubishi Starion turbo 10 psi, megasquirt, and 3" exhaust.
170.74hp and 167.86tq.
hmmm you got me thinking now 325isdan.
Old 08-11-2014, 09:46 PM   #23
325isdan
If you keep boost low you should be able to keep the motor stock. I have a super charged s50 in my e30 that is completely stock. running 5psi What kills motors is over revving. You're probably looking at 5gs for a swap to be done.
Old 08-11-2014, 11:22 PM   #24
Stance Factory is by far the shop for swaps! Just look at some of the cars they have done if you have any doubts! We can also supplie a good M52 and 5spd, among other things!
Old 08-12-2014, 05:47 AM   #25
partner103
No doubts Sir... Spoke to Jay when you were there with your touring about a month or two ago, and unfortunately they are only S54 now.
Believe me I tried, in fact I thought about buying the motor from you guys. Can you pm me some numbers on a full M52 swap please?
But Jay and Mike no longer deal with anything less than an S54.
I'll probably try RMP as well. To see what they say. I've had good experiences with them as well.
Old 08-12-2014, 08:15 AM   #26
partner103
I'll give some more thoughts to the turbo options. Not rushing into anything. Want to make sure I do it the right way.
Old 08-12-2014, 10:01 AM   #27
Woofer
Woofer's Avatar
I'm tempted to want to take on the job. Do you have all the parts needed? Motor, tranny, oil pan and pick, etc etc?
Old 08-12-2014, 10:26 AM   #28
partner103
Not yet, but I'd procure that from BimmerHeaven most likely.
I am looking at the winter months, potentially early 2015. Gotta get $$$ together.
Old 08-25-2014, 02:36 AM   #29
danielbignal
has anyone done a m62 swap, just curious, how much harder is it to swap then a s/m5x
danielbignal is offline   Reply With Quote
Old 08-25-2014, 08:17 AM   #30
frankie591
It is an extremely more complicated swap. M60's don't make enough power to be worth it IMO. If you were to go to the trouble of doing a v8 swap do an S62 at least, or an LS-x.
