Really awesome brake fluid chart here. Maybe sticky?
ATE Typ 200 is clearly the value winner for wet boiling point vs cost per/oz.
http://www.lelandwest.com/brake-flui...ison-chart.cfm
Note the values for EBC DOT 4 are incorrect. EBC has the wrong values on their site. It was so good I emailed them just to be sure. Here are the correct values
EBC Dot 4 brake fluid has a dry boiling point of 268*C (514*F) and a minimum wet boiling point of 165*C (329*F)
EBC BF-307 has a dry boiling point of 307*C (586*F) and a minimum wet boiling point of 196*C (386*F)
I'm not gonna format this correctly, just go to the link. Just put the values here in case the site goes down.
Mfr Type DOT Wet Boil Dry Boil Mix? Oz Qty Price per Oz SKU Price Link Notes
Castrol React SRF 4 518 590 Yes 33.8 2.07 69.99
EBC DOT 4 4 500 * Yes 8.8 0.34 2.99 motorcycle
Torque RT700 4 439 683 Yes 16.9 2.01 33.95
Project Mu G-Four 335 4 430 635 NO 33.8 1.77 59.95 Changes color when boiled
Endless RF650 4 424 622 Yes 16.9 2.49 42.00
Motul RBF 600 4 421 594 Yes 16.9 1.06 17.99
Comar GS610 4 421 610 Yes 16.9 Old Stock
Neo Synthetics Super Dot 610 4 421 610 Yes 16 1.56 24.99
Galfer Super 5.1 419 572 Yes 16.9 0.77 12.99 motorcycle
Wilwood EXP n/a 417 626 Yes 16.9 1.05 17.69
Maxima SYN Hi Temp 4 410 600 Yes 12 1.17 13.99 motorcycle/auto
The Brake Man Xtreme 6 5.1 400 612 Yes 16.9 1.48 25.00 mfr says wet boil is "over 400"
AP Racing PRF660 4 399 617 Yes 16.9 1.72 28.99 Do not use with magnesium parts
Motul RBF 660 4 399 617 Yes 16.9 1.72 28.99
Brembo LCF 600+ 4 399 601 Yes 16.9 1.12 18.99 Do not use with magnesium parts
Ferodo Super Formula 4 399 626 Yes 16.9 1.12 18.99
Pagid RBF 4 399 622 Yes 16.9 1.52 25.75 "DOT4 compliant"
Fuchs Silkolene Pro 4 399 594 Yes 16.9 1.59 26.95 motorcycle
AP Racing Radi-CAL R4 n/a 399 644 Yes 16.9 2.32 39.25
ATE Typ 200 4 396 536 Yes 33.8 0.50 16.99 'Amber'
ATE Super Blue 4 396 536 Yes 33.8 US DOT: 'cease and desist'
Prospeed RS683 4 394 583 Yes 16.9 1.48 24.99
StopTech STR 600 4 383 594 Yes 16.9 1.00 16.95
StopTech STR 660 4 383 622 Yes 16.9 1.65 27.95
Tilton TBR-1 4 383 590 Yes 8.5 0.92 7.86
Tilton TSR-1 4 383 622 Yes 8.5 1.40 11.90
Performance Friction RH665 4 383 617 Yes 16.9 1.77 29.99 Motorex Racing Fluid 4 383 563 Yes 16.9 1.52 25.75 motorcycle
Amsoil Series 600 4 380 580 12 1.17 14.05 Endless S-Four 4 369 563 Yes 33.8 1.01 34.00
AP Racing Formula DOT 5.1 5.1 369 516 Yes 16.9 0.88 14.95
Motul DOT 5.1 5.1 365 522 Yes 16.9 0.59 9.95
Ferodo ESP DOT4 4 361 516 Yes Not sold in U.S.?
Repsol Moto 5.1 356 500 Yes 16.9 0.59 9.95 motorcycle
DOT5.1 Minimum 5.1 356 500 Yes Glycol
Pentosin Super DOT 5.1 5.1 356 500 Yes 16.9 Not sold in U.S.?
Motorex DOT 5.1 5.1 356 * Yes 8.5 1.18 9.99
Ferodo DOT 5.1 5.1 338 518 Yes 8.5 1.06 9.00
ATE SL.6 4 338 509 33.8 0.47 15.95 ultra-low viscosity
Pentosin DOT4 LV 4 338 509 33.8 0.53 17.95 ultra-low viscosity
Brembo Sport.EVO 500+ 4 336 520 8.5 1.18 9.99
Maxima DOT 4 4 332 510 Yes 12 0.58 6.95 motorcycle/auto
Pentosin Super DOT4 4 329 509 Yes 16.9 0.59 9.95
ATE SL 4 329 500 Yes 33.8 0.41 13.95
Ferodo DOT 4 4 316 480 Yes 8.5 0.70 5.99
Motul Synthetic DOT 3 & 4 4 316 473 Yes 16.9 1.74 9.70 discontinued?
Wilwood 570 3 313 573 Yes 12 0.66 7.89
Castrol DOT 4 4 311 446 Yes 12 0.58 6.99
Bel-Ray Super DOT4 4 311 446 Yes 12 0.75 8.95
Valvoline DOT 3 & 4 4 311 480 Yes 12 0.37 4.49
DOT4 Minimum 4 311 446 Yes Glycol
AP Racing 551 3 304 516 Yes 16.9 0.76 12.79
Amsoil Series 500 3 304 520 12 0.64 7.65
ATE G 3 302 473 Yes 33.8 No longer for sale?
The Brake Man Super Man 577 3 300 577 12 1.83 21.95 DOT type unstated. Meets DOT 3 wet boil spec
AP Racing Super 600 n/a 299 594 NO 16.9 1.27 21.49 Do not use with magnesium parts
Ford C6AZ-19542 3 290 550 Yes 12 0.58 6.95 'Heavy Duty'
DOT3 Minimum 3 284 401 Yes Glycol
Performance Friction Z-Rated 3 284 550 Yes 16 0.53 8.42 Wrong boil point listed in seller link
EBC BF 307+ 4 196 585 Yes 16.9 0.87 14.99
Brembo HTC 64T 4 * 635 Yes 16.9 1.95 32.99 Do not use with magnesium parts
Gunk DOT 4 4 * 446 Yes 32 0.25 7.99
Gunk DOT 3 ABS 3 * 450 Yes 32 0.22 6.99
Gunk DOT 3 3 * 401 Yes 32 0.19 5.99
Ultra Lite Hot Fluid 4 * 600 Yes 32 1.09 34.99
AFCO HTX 4 * 600 Yes 16.9 1.06 17.99
AFCO HT 4 * 500 Yes 12 0.50 5.99
