Old 05-21-2014, 10:15 PM   #1
Danny51
Danny51's Avatar
Fuel Pump or Fuel Pump main relay????
Hey Guys !
Last week my E30 Stopped running while I was driving, fuel stopped going to the engine and it just died on the road.
I recently changed the Fuel Filter so I know its not that,
Ive narrowed it down to Fuel Pump and Fuel pump main relay. I took out the rear seat, held my ear to the fuel pump cover while someone started it and couldnt hear anything except the motor trying to start.
Anyone got anything? Im trying to get this fixed asap
Thanks !!
Danny51 is offline   Reply With Quote
Old 05-21-2014, 11:09 PM   #2
bimmere30
Hi
It could be the fuel regulator or fuel pump connector that has corroded or fuel relay. Did you work in that area recently?
bimmere30 is offline   Reply With Quote
Old 05-22-2014, 12:19 AM   #3
Danny51
Danny51's Avatar
Fuel Pump was changed 2 years ago, so someone did.
Old 05-22-2014, 06:30 AM   #4
DET1990
check for voltage at the fuel pump plug and if you get 12 volts you will know that it is the fuel pump that has failed and not the relay
DET1990 is offline   Reply With Quote
Old 05-22-2014, 07:56 AM   #5
You have to know which model pump you have based on the year of the car. If it's a late 325 you probably have a single fuel inlet with 2 connectors. if it's earlier model pre 88 then it's a duel inlet pump. if it's a 318 its a dual inlet with a twin connector. the black connector on all is the sending unit. Some have a flat spade connector and some have the pin connector.
Old 05-22-2014, 03:49 PM   #6
bimmere30
Hi
It should be the fuel connector there is one on ebay, or u can just find a e36 wire harness with fuel connector I think it will work for e30 fuel pump as well
Old 05-22-2014, 05:36 PM   #7
pumps get around 200k out of them. Seen this happen quite a few times.
Old 05-22-2014, 06:44 PM   #8
/thread.
Old 05-29-2014, 09:07 PM   #9
Danny51
Danny51's Avatar
Late update, but I found out in the end it was in fact the fuel pump. Had it replaced and shes runnin perfect again !
Thanks guys !
Old 05-29-2014, 11:43 PM   #10
bimmere30
How much u spend on your fuel pump? It cost A fortune from dealership...
Old 05-30-2014, 12:25 AM   #11
Danny51
Danny51's Avatar
I got full assembly (Pump+sending unit) for $230. To be honest I didn't shop around much and just wanted to get it running asap
My accumulation of E30s so far..
1991 318is - Rustbucket
1984 318i - Hennarot M50 Swap
1992 Convertible - MTECH 2
1991 318is - S52 Swapped
