Old 03-30-2014, 08:21 PM   #1
windwagen
windwagen's Avatar
holy touring
I'm prepping my touring for the Msport makeover when I discovered 9 holes behind the rear bumper. They all have a clean ring around them suggesting plugs that were recently removed. There was a single plug still in place but it disintegrated when I touched it.
I'm going to get some replacements but I find this quite disturbing since water can get in easily. I suggest everyone to check their touring. Do sedans have these holes too?
E39 528i Touring - Unicorn Package (5 Spd M)
E39 M5 - for Sunny Days
Old 03-31-2014, 02:29 AM   #2
v_bimmer
Jailbait FTW
v_bimmer's Avatar
your rear tires look scary
Old 03-31-2014, 02:36 AM   #3
1bmw1
What's the purpose of those holes? Is it like that from factory?
Old 03-31-2014, 07:22 AM   #4
jabela
Probably crash absorption.
www.maisonapothecare.ca
Old 03-31-2014, 07:28 AM   #5
cheapthrills
Measure the diameter of the hole, and buy the plugs with the following part numbers. Hopefully they're less than $1 each.
8mm = 51718204406
12mm = 51718110199
13.5mm = 51711974209
15mm = 51718170298
17mm = 51221924979
20mm = 07147140850
25mm = 51718126605
28mm = 51718138511
35mm = 07147140849
When I bought my car, the rear tires were pumped to 45 psi (the max pressure rating on the tire sidewall). The centers were bald but the shoulders had plenty of meat left. It made the handling in the rain rather interesting.
cheapthrills is offline   Reply With Quote
Old 03-31-2014, 08:19 AM   #6
windwagen
windwagen's Avatar
No kidding! They were fine at the beginning of winter. I had it set to the lowest recommended pressure. Half way through the winter I set it to the max. No wonder why the acceleration in the snow was horrible.
Thanks Cheapthrills...
Old 04-02-2014, 06:49 AM   #7
325isdan
Clearly those are speed holes.
325isdan is online now   Reply With Quote
Old 04-02-2014, 07:38 AM   #8
windwagen
windwagen's Avatar
I thought they were A - holes
Thanks again Cheapthrills - I got them from the dealer. It's hard to tell which are the right ones from the "computer", but your 25mm reference matched one of the listings.
Old 04-02-2014, 10:36 PM   #9
windwagen
windwagen's Avatar
Oh maaaan
I was so excited to get my msport bumpers back from the bodyshop.... I totally forgot about the holes. I installed the bumper without even picking them up from the dealer! Doh
Old 04-03-2014, 09:48 AM   #10
jrsmitchell
Switchtronic
jrsmitchell's Avatar
Originally Posted by windwagen View Post
Oh maaaan
That's totally something I would do. Well at least you already know how to get the bumper on and off.
Jeff | '94 BMW Alpina B3 | '06 BMW 325XI Wagon
jrsmitchell is offline   Reply With Quote
Old 04-03-2014, 06:28 PM   #11
windwagen
windwagen's Avatar
Lucky for me... The holes are accessible after removing the black valence. Whew...
Old 04-04-2014, 12:35 PM   #12
Wait, you set the tire psi to max during the winter???? Why?
Old 04-04-2014, 04:16 PM   #13
TSI
Reverse Gear Member
I did the same...not much snow and my commute was at 10pm, so little traffic and much speed.
Old 04-04-2014, 04:30 PM   #14
windwagen
windwagen's Avatar
To save gas .... and instead ... kill the tire.
When I first put this thing on the road, there was a lot of noise coming from the trunk going over bumps. I didn't know if it was normal so I set the tire pressure really low. I tightened up a lot of trim on the hatch but I think the true source was the spare tire. Somehow if you tighten the fastener, which is attached to the air suspension pump, the noise resonates. Eventually I cut up a pizza box and slipped it under the tire and left the fastener somewhat loose.
Old 04-05-2014, 11:02 PM   #15
This thread makes me LOL. Thank you.
