Old 11-23-2013, 06:29 PM   #1
eyelevel
eyelevel's Avatar
My e30 325e is not economical
I have a 1987 e39 325e and I get 390km/tank of gas.
The fuel consumption indicator goes to the extreme when I accelerate and goes to zero (sometimes) when I let off the gas. put in a new O2 sensor. Would changing the cluster fix it. Does anyone know what controls this operation. Vacuum system?
2002 e39 530i non-Winter driver
1973 Bavaria 3.3L Leather, 2x2bbl Webber, K&L 97k Miles,
1972 Bavaria 3.0 L in process of restore
Previously owned
'87 e30 325e coupe
'90 e30 325i Vert
'95 e38 740iL
eyelevel is offline   Reply With Quote
Old 11-24-2013, 01:09 AM   #2
frankie591
no the cluster wouldn't do anything. Check for vacuum leaks, read your plugs to see if you have a stuck open injector are some of the first things you should do
FYI in my 325i at no throttle my fuel economy gauge reads zero, when I give any amount of throttle the gauge shoots up to 40l/100k and stays there lol
Old 11-24-2013, 02:19 AM   #3
JohnnyK
I feel compelled to chime in as I hunt for seats.
The mileage gauge SHOULD read 0mpg when you're not moving. No codes? Vacuum leak would probably cause a funky idle.
ANd I'm not sure about your BMW's specifically, but it's probably a combination of vacuum and VSS that controls that (Just a guess). When vacuum is high and VSS is reading 0, it knows you're at 0 mph, and mileage should read 0. What IS your vacuum at idle?
JohnnyK is offline   Reply With Quote
Old 11-24-2013, 05:53 AM   #4
ac_2007
Cruising in Top Gear
ac_2007's Avatar
sounds like the gauge is working exactly as it should. its showing you instantaneous (estimated) fuel mileage based on your throttle position.
MPG/ liters per KM is an average.
Old 11-24-2013, 09:54 AM   #5
Gauge is functioning normal. ^^^
Old 01-14-2014, 01:11 PM   #6
estoguy
Check for vacuum leaks. I'd also recommend running some SeaFoam through your car, gas and intake. Have you checked your ignition components? I'd pull the spark plugs too to see what they look like - could indicate a problem.
I have owned an Eta for over a year, and my total average has been 7.6L/100 KM. I've gotten it below 7 during warmer months on long drives. The winter kills the efficiency by about 15%. Right now, running around 8L/100 Km.
1986 325 ~Elsa~
Alpenweiss
Need a photographer, come visit my site: http://estoguy.wix.com/unique-perspectives
"The future is uncertain and the end is always near."
estoguy is offline   Reply With Quote
Old 02-13-2014, 02:22 PM   #7
bmr999
I have a very similar problem with '89 325ix, except my gauge at idle does not sit low (0 L/km) my sits off the charts at the high end of the scale. I am looking at swapping the AFM to see if that solves the problem. If I learn anything I'll post some results.
bmr999 is offline   Reply With Quote
Old 02-13-2014, 03:29 PM   #8
This is normal, when you are not moving, your gas consumption is 100%...
Old 02-15-2014, 03:33 PM   #9
bmr999
Thanks euro now that I think of it that is spectacularly obvious.
