Old 01-31-2014, 10:29 PM   #61
It was done to allow for lots of castor and massive steering angle on a drift car... hence the cut out wheel wells
Old 02-02-2014, 12:25 PM   #62
Yamahammer
Warlock of the century
Yamahammer's Avatar
It just looks like it was not thought out very well.
Old 02-03-2014, 11:31 PM   #63
When haven't I been? lol
I'M IN GUELPH!!
Old 02-05-2014, 06:33 PM   #64
Sea Aych
Sea Aych's Avatar
So who's having fun out there today? Where I am, it doesn't look like any salt's been put down either
Sea Aych is offline   Reply With Quote
Old 02-06-2014, 10:18 PM   #65
DIY
Permanently Dirty
DIY's Avatar
fun? I was slaving in the kitchen allll day... you know how tiring it is baking doughnuts for that long? but it can be disappointing when they come out with the faint smell of rubber .... oh well at least it was fun lol
on a side note.. who actually learned to control their ABS??
Old 02-07-2014, 09:52 AM   #66
wut?
Old 02-07-2014, 10:37 AM   #67
LOL! You made it obey to sit, pee, and jump...?
Old 02-07-2014, 11:22 AM   #68
Roysneon
Roysneon's Avatar
wut?
I think he was referring to braking without getting it to kick in on snowy/icy roads.
Old 02-07-2014, 11:29 AM   #69
He's trolling.... half of the E30s on the road don't have working ABS lol
Old 02-07-2014, 11:35 AM   #70
frankie591
On a side note, since I am pretty much internet-illiterate, does anybody have a link to a how-to on how to embed pics in a post? I have traditionally used the attachment feature in the post creation screen but it wasn't working for me lately.
There's some way I can upload pics to photobucket or something like that and just drop them into my posts?
Old 02-07-2014, 11:47 AM   #71
Really though... it's a bit of a subjective topic. Mostly to do with what tires you have, conditions, etc etc. IMO, you cannot beat ABS (even though it's not that advanced of a system on our E30s) so why try to trick the beast? It's there to help.
Haha. Truth!
Use IMG tags like this:
[IMG]paste your URL here[/IMG]
Old 02-07-2014, 06:22 PM   #72
Ryan1212
Some sort of something...
Ryan1212's Avatar
Steve, here is my version of the rad support as well. Frankie's is different to mine which you will see when he figures out how to use the forum haha
Yes I went a "little" overkill with the bolts using 6 m6's per plate lol.
The only modification I had to make outside of this was notch the plastic grills in the front and the headlight brackets a tiny bit. It all goes back together and looks completely stock from the outside. This will work for stock motor setups.
Too bad I now need to cut it apart and remake the center section out of tubing and be able to tilt my rad by about 20deg for my project, ah well.
Ryan1212 is offline   Reply With Quote
Old 02-07-2014, 06:48 PM   #73
frankie591
Here is my rad support. Made it so that I could mount my x-line 3-core rad far enough forward to still fit a puller fan and shroud in front of my motor.
[IMG][/IMG]
Left room for a future intercooler install, here you can see my homemade aluminum fan shroud. The fan is a 2" thick SPAL so it should keep things nice and cool.
[IMG][/IMG]
Here you can see where the rad and fan shroud sit. I think I have gained clearance vs the stock rad in the stock position.
[IMG][/IMG]
This shows where how the rad fits within the support. It was very difficult fitting it between the frame rails, the support itself is 1x1" steel tubing, mitre cut etc.
[IMG][/IMG]
Here is my rear brake setup. The stock tee has been relocated to an accessible location, and braided stainless lines go from there to each caliper. You can see the poly diff bushing I machined out, and you can kinda see my rear sway bar setup. Once I finish fabrication of the sway bars I will post a more detailed look at em.
[IMG][/IMG]
Also, my vert celebrated an anniversary lately. That puts me over 600k for both my e30's combined.
[IMG][/IMG]
Old 02-07-2014, 07:00 PM   #74
Sea Aych
Sea Aych's Avatar
lol was gonna say - Every piece associated with my abs under the hood looks like it was smashed with a hammer by one of the many POs
Got my euro grilles popped in today after a last coat of paint!
Also trying to locate a weird clunking whenever i hit a bump that sounds like it's coming from inside the rear doors.. Gonna be a fun evening
Old 02-08-2014, 11:14 AM   #75
Subframe bushing?
