Thread Tools Rating: Thread Rating: 2 votes, 4.00 average. Display Modes
Old 10-26-2013, 05:18 PM   #1
rwdbmwm3
ACTIVATING DRL ON 08 328i
I am trying to activate DRL through the cluster, but when I go into it I do not see the DRL symbol
The little SUN looking one shown in picture below
instead it shows me the Turn Signal x3 below the P= one
why?......
rwdbmwm3 is offline   Reply With Quote
Old 10-26-2013, 09:06 PM   #2
Revision2
Revision2's Avatar
Probably because DRLs are mandatory in Canada so having the option to enable/disable it probably wouldn't make sense.
Revision2 is offline   Reply With Quote
Old 10-27-2013, 12:29 AM   #3
DimSumE90
You have to have it coded.
www.littlebimmer.com
DimSumE90 is offline   Reply With Quote
Old 10-27-2013, 10:07 PM   #4
DIY
Permanently Dirty
DIY's Avatar
are programming things like that just in the manual? where can I find whats possible with those kind of programming changes, I F'n hate when my car dings at me!!
Old 10-27-2013, 11:32 PM   #5
jcr
You'll need a special cable, and software to code it into your car.
jcr is offline   Reply With Quote
Old 11-01-2013, 10:41 PM   #6
rwdbmwm3
Anyone in kitchener have the tools to do this?
I got a problem where my right drl works but my left one doesn't
Not getting power from green wire (I think it was green)
Old 11-02-2013, 12:29 AM   #7
jcr
I believe the left and right are all controlled by the same circuit.
Old 12-14-2013, 10:50 AM   #8
MANDD
Autobahn East
The DRL is a coded feature for the Canadian market, it can not be changed by the operator. The only way this can be done is through coding/adjusting VO.
If it is just one light not working you should check the bulb, the FRM will remove current to a open or shorted bulb.
Mark.
Old 10-01-2014, 12:23 AM   #9
rwdbmwm3
i checked bulb but im actually not getting power coming out of the wire that goes to the light
can i buy that cable/software somewhere for reasonable price?
or anyone locally have one to fix this?
Old 10-01-2014, 12:31 AM   #10
jcr
Don't think the cable and coding tools will help you in this case.
Are you using the standard halogens in your DRL? If you're using aftermarket non-halogens then that might be causing some of the problems.
You are not getting and trouble code for this?? I would think it would set off a code.
09 E90 328i 3IM, Eurocharged, K&N, 80W LED Angel
Coding: Digi Speed, Express Up Fob, Wipe Wash Count, Weather Station, Headlight Sensitivity
Old 10-01-2014, 12:50 AM   #11
rwdbmwm3
ill scan the car again but i didnt see any codes
I just have the left front drl out .light on dash
and i got as far as diag'ing that i have no power on the green wire (i believe - i havent looked at it for a bit)
If i grab power from the other drl (right side) the light turns on but the dash light stays on that its out
i am not sure if i need to get something activated or coded
as a side note i had OEM hid's - one of them was giving me issues so i just bought ones off ebay with the CCFL (i dont care what lights are in it i just want the light to go off the dash and the lights to function properly)
Old 10-01-2014, 12:52 AM   #12
jcr
Not sure the wiring on the car but also check the fuse?
Old 10-01-2014, 03:28 AM   #13
DimSumE90
His problem can be fixed. I've repaired many cars that has the same problem. BMW diagnosis is to fully replace the module.
Clients have came to me with cars that have one side angel eyes dead even with replaced new bulbs. It's a 10 min software fix.
Old 10-01-2014, 08:49 AM   #14
why?......
This option isn't available on Canadian cars. If you DRL's aren't working then someone hasn't turned them off through coding.
You'll need a L+DCan Cable and NCS Expert to code whatever module you'd like.
Just do it at your own risk. Once after coding, my car failed to start. Immobilizer kicked in for some reason and the only was I got myself out of that was using DIS.
doogee is online now   Reply With Quote
Old 10-01-2014, 05:29 PM   #15
DimSumE90
His problem is not just simply coding DRL's to be turned off or on. He has issues with one of his power lines in the FRM module being blocked. Hence there is voltage to one side and the other is disabled. NCS Expert will not solve this issue. Any experienced coder who knows what they are doing, will know that not even flashing the module will fix it. This is something most experienced coders will know.
