Old 11-22-2013, 05:55 PM   #1
99528i
no sound
I just bought a 99 528i and it had an after market deck in it that didn't work so I bought a new one and wired it in and I have power to my deck but no sound from my speakers can any one help me with this problem?
99528i is offline   Reply With Quote
Old 11-22-2013, 06:08 PM   #2
does no sound come at all or only when you try to play cd. does FM work?
if no sound period, the ACC wire is disconnected from the amp.
if no sound on CD (but works on FM), the acc wire is wired to the antenna.
Old 11-22-2013, 06:13 PM   #3
99528i
nope I get no sound at all dosent matter if its on c.d aux or radio
Old 11-22-2013, 06:43 PM   #4
your amp is probably not getting acc power from the HU
Old 11-22-2013, 08:07 PM   #5
99528i
wheres the amp located?
Old 11-22-2013, 09:07 PM   #6
in the trunk, but the wiring would be behind the radio. its probably a blue wire, or a white wire with a blue stripe.
Old 11-23-2013, 11:06 AM   #7
99528i
I took a volt meter and I am getting power to the amp
Old 11-23-2013, 11:53 AM   #8
be sure you're taking the readings correctly, the amp always has power, but only turns on when the ACC wire is hot.
If you have a spare speaker you can try wiring one of the outputs of the deck directly to the speaker. You should hear music (albeit very quietly since its only using the internal amp on the HU)
Old 11-23-2013, 01:11 PM   #9
Did the previous owner make any changes to the stock wiring? Maybe he had a system in there and ripped it out before giving it to you.
I'm that case you'll probably have to trace each wire to see what he might have done. Maybe he by passed factory amp and ran wires to each speaker to an amp that is no longer there.
Old 11-23-2013, 01:46 PM   #10
<3MyE36
-Richy Nevaless-
<3MyE36's Avatar
My father's E39 had the same problem, it turns out the Harness Adapter was missing a piece, check to see that your Harness Adapter is correct for your car, and if you think it is try wiring your OEM deck back in to see if it works.
-Rich
<3MyE36 is offline   Reply With Quote
Old 11-23-2013, 01:58 PM   #11
99528i
yeah this guy just cut wires and hardwired it in
