I have an extra bottle of each both are brand new.
ATE TYPE 200 Amber Brake Fluid - Asking $15
designed to excel within the extreme demands made on a race vehicle or by high performance drivers and exceeds all DOT4 standards. It is compatible with and will mix well with most DOT3, DOT4 or DOT 5.1 fluids.
Features/Benefits of ATE TYP 200 Amber Brake Fluid:
Boiling point minimum: 536 degrees F
Wet boiling point minimum: 388 degrees F
Viscosity at -104 degrees F: max 1,400 mm 2/5
Pentoisin ATF1 - 1 Litre $20
Automatic Transmission Fluid - Pentosin ATF Part# 1058107
Excellent replacement for ZF transmission Lifeguard 6 transmission fluid which sells for over $50 a litre at BMW, Lincoln and Hyundai Dealerships!
