Thread Tools Rating: Thread Rating: 4 votes, 4.50 average. Display Modes
Old 11-17-2005, 07:10 PM   #31
ara_yaz
Bimmer Fan
ara_yaz's Avatar
Originally Posted by thinair
Better late then never
true, true...thanks dude. It's funny that as I was watching tv last night, i saw a commercial for Sta-Bil gas stabilizer...i don't remember seeing that before...did you have someting to do with it?
ethirty
ara_yaz is offline   Reply With Quote
Old 12-04-2007, 04:19 AM   #32
Gamite
Gamite's Avatar
forgot to sticky this thread this year. "Better late than never."
www.gamite.net
Old 12-07-2007, 02:14 AM   #33
sreeja
I just heard about this.It is nice.Is it gives a fresh look ever?I cannot believe this.
http://wslaat.com
sreeja is offline   Reply With Quote
Old 01-06-2008, 03:34 PM   #34
KillerPM
The only suggest I can add is leave the car in 2nd gear (for all us MT guys, 1st gear for guys who have a dogleg transmission). This keeps the transmission selector rod pushed in as far into the transmission as it can be. Keeps it from getting corroded and keeps that transmission seal working better come spring.
BMW
KillerPM is offline   Reply With Quote
Old 09-19-2008, 12:04 AM   #35
nX07
nX07's Avatar
So much things to take into consideration it almost makes me want to just drive the car once a week or so in the winter lol!
nX07 is offline   Reply With Quote
Old 09-22-2008, 05:13 AM   #36
^^lucky you. for me to drive my car in the winter involves a border crossing, a 5 hour long drive, re-installation of wheels/battery/lighting systems, flushing fluids and then realizing i still can't go anywhere cause i dont have winters.
but its ok, winter sucks, but i got another bmw for that.
Old 01-20-2010, 01:28 PM   #37
Dammerung
Dammerung's Avatar
Where can i find trickle chargers? can i put it on the battery even when the battery is in the car?
Die Dämmerung..............when dusk began to fall, when dawn begins to break
Dammerung is offline   Reply With Quote
Old 02-09-2010, 03:03 AM   #38
Dammerung
Dammerung's Avatar
Originally Posted by X5HogTown View Post
Be sure to put the stabilizer in the tank before topping it up in order to give it a good mixing. Run the car for a good 5-10 minutes to make sure the stabilizer gets through the fuel line and injector system.
Just a quick question. I end up driving my car once a month for a good hour. But its basically in storage for a good 6 months. should i add stabalizer? Should I fill the tank after every use as well?
Old 12-25-2011, 12:59 AM   #39
AdrianL
Live from 42,000'
AdrianL's Avatar
Trickel chargers can be found at canadian tyre. Put in stabilizer if it's sitting for a month or more. Less than that I wouldn't bother.
AdrianL is offline   Reply With Quote
Old 04-24-2012, 03:23 AM   #40
M3habib
M3habib's Avatar
question regarding "placing plastic under the car"... this is the first iv heard of it, cant you have a big old rug underneath, would that prevent the moisture too?
Iv always used a thick piece of rug under each tire, KEEP IN MIND, if the rug gets wet someway somehow, the moisture will damage your tires more then having it sitting on concrete
M3habib is offline   Reply With Quote
Old 04-24-2012, 12:48 PM   #41
MrRWD
A rug would be bad. Concrete will always let moisture come up from the ground (unless it is fully sealed - epoxy coating). This is a general practice, and really depends on the water table in your area.
Carpet pieces or large foam for the tires are important to insulate the tires from the cold concrete.
This is the same reason, most seasoned carpet installers don't recommend hardwood or laminate flooring in the basements. Carpet with an good underpad will still breathe.
For hardwood/ laminate in the basement, you need some kind of thermal and moisture break - raised floor, with that plastic dimples on the back.
MrRWD is offline   Reply With Quote
Old 10-13-2013, 10:55 AM   #42
Jay22
Shadows.
Jay22's Avatar
When do you guys usually store your cars? This is my first year of storing my new-to-me E90 - with the E46 it was one the road 365 days a year - Im guessing mid november?>
Jay22 is offline   Reply With Quote
Old 09-29-2014, 11:02 PM   #43
croweprod
For me, as soon as the salt hits the road, time to bring it in. The rust on my acura would stay pretty much the same all summer, then the first salting, and wow, the sheet metal would start crumbling!
croweprod is offline   Reply With Quote
Old 10-24-2015, 04:59 PM   #44
BestodaBest
Almost that time of year again
BestodaBest is offline   Reply With Quote
Old 10-28-2015, 09:26 PM   #45
david bilton
RED ZED
david bilton's Avatar
when to store
First snowfall of sufficient amount to bring out the salt trucks is my trigger. The low temperature warning beep has already jolted me awake this week when it was 3 degrees C outside, but I left the roof up and employed the excellent heater.
David Bilton, Brighton ON Canada, 2007 Z4 purchased Sep.21/2015 with 18153 KM (11280 miles) in almost New condition. First BMW was 1999 328i convertible from May 2011 to May 2014
david bilton is offline   Reply With Quote
