Old 10-02-2013, 09:53 AM   #1
alaadeen
Exclamation Winshield Washer fluid level in E90
Has anyone encountered low washer fluid warning in your E90 onboard computer? I get the warning barely a month after I put in a full gallon of the washer fluid. I do not even see the washer fluid leaking from anywhere.
Any clue what is happening?
alaadeen is offline   Reply With Quote
Old 10-02-2013, 10:03 AM   #2
Blades
Your opinion is to long
Blades's Avatar
its sprays a lot on your headlights .. people usually forget about that
-=[ BL/\DES ]=-
Old 10-02-2013, 12:12 PM   #3
alaadeen
Agreed. But i used the winshield fluid not more than 2-3 times. And I used it in a restricted manner.
Old 10-02-2013, 01:35 PM   #4
Blades
Blades's Avatar
maybe a small leak from the hose or the bottle .. some say the bottle cracks from the bottom
-=[ BL/\DES ]=-
Old 10-11-2013, 10:06 AM   #5
alaadeen
it was a crack - you are correct. dealer fixed it for free during routine service.
