Old 04-26-2011, 04:29 PM   #61
Bimmerized
In BMW We Trust!
Bimmerized's Avatar
Send a message via MSN to Bimmerized
Originally Posted by ruben7 View Post
Ahh yes, the good old "running the new wire" method lol. I was hoping the simpler method in this thread would work but I guess not
Let me know how it goes once you give it a shot, and what tools/parts you need.
PS: Do you also have the 3 red/green wires as opposed to 5?
I never even bothered to check for that method....according to all the threads and info in here i just figured pre 95's are wired differently...but once I get to it I will check and let u know!
Bimmerized is offline   Reply With Quote
Old 04-27-2011, 02:04 AM   #62
Bimmerized
In BMW We Trust!
Bimmerized's Avatar
I checked it and I don't have the 5 wires either, I just have the 3....anyhow I went with the other method and it was very simple, same as it is laid out on the write up.
Literally just open the fuse box and find wire 86 (green/red....there is only one green/red and it's thinner than the rest of the wires) under the low beam relay, cut it but leave it longer on the relay end (so pin 86) and here is where you attach a wire and run it through the firewall inside the car, and just attach it to the yellow wire coming from the lights switch (there is only one yellow wire there, you don't cut this wire just strip it and attach the new wire that you ran from the relay), and it works perfect.
Old 04-27-2011, 01:43 PM   #63
ruben7
Sweet, gonna do that this weekend
Are the dash lights also off on switch position 0? Can I use any extra wire I have at home or is there some specific type, and was duct tape fine to cover the connection?
ruben7 is offline   Reply With Quote
Old 04-27-2011, 01:49 PM   #64
Bimmerized
In BMW We Trust!
Bimmerized's Avatar
The dash and corners remain always on, the only thing that turns off is the low beams, which is what I wanted cus I have HID's, but that's the bummer part about this I guess!
I soldered and heat shrank everything .
You should not use duct tape in any electrical connections , but it's up to you, electrical tape is cheap.
Good luck, let me know how it turns out!
Old 04-27-2011, 02:11 PM   #65
ruben7
Yeah I meant electrical tape. And nooooooooooo....I hate the corners.. T.T no way to shut them down?
Old 04-28-2011, 02:04 PM   #66
ruben7
Here's how to get rid of the corner daytimes.
1. Remove turn signal bulb.
2. Grab a piece of electrical tape and cover one of the metal connectors of the bulb (one is for the daytime and the other is just for flashing)
3. If it doesn't work it's because you covered the wrong connector, try covering the other one.
http://i52.tinypic.com/2086tef.jpg
Works good , credit goes to Vander @ bimmerfest
Bimmerized, where did you buy the wire for your connection? Is there any specific type?
Old 08-27-2013, 12:09 AM   #67
153624
Owner of a Slow Car
After eight hours spent poring over the ETM for my 93 I've managed to undo the extra wiring BMW put in to hardwire the DRL's. I took a bunch of pictures so I'll probably post a DIY in the next few days. It's a similar solution to the one the OP did.
153624 is offline   Reply With Quote
Old 08-27-2013, 12:10 PM   #68
Dr. Flyview
"Mint"
Dr. Flyview's Avatar
Nice, please post it up!
1998 BMW 328is - summer
1993 BMW 525i - daily
1994 BMW 325i - sold
1992 BMW 325i - gone
sold
Old 08-28-2013, 04:50 PM   #69
153624
Owner of a Slow Car
Posted! Hope it helps someone.
