Old 08-20-2013, 01:16 PM   #1
Marc124444
Z3 COUPE track car still legal for street 22500$
2001 BMW Z3 COUPE E36/7 M- Package
US car, professionnally rebuild by the Camirand and plated since 2003, No winter oil treated 2008-2009-2010.
Bought at 15,000$ + 15,000$ upgrade with all the bills
Engine
TMS/CONFORTI performance engine software (+4hp, +7tq)
AEM dry flow 3.5’’ filter, Custom 3.5’’ tubing
LIQUIMOLY 10w60 GT1 Synthoil race tech
Z3 Supersprint exhaust
IRELAND ENGINEERING Oilite bronze clutch pedal bushings Z3
AKG 75D engine mount bushings
TURNER MOTORSPORT Power pulley upgrade kit
UNIVERSAL O2 simulator
Stainless steel performance headers NO NAME
Cooling
E46 M3 oil cooler w/shroud & oil cooler hoses
E46 6-cyln euro oil filter housing (S54) adaptor banjo bolt for Vanos
Bimmerworld E36 3 serie electric fan conversion kit
Transmission
E30 M differential medium case cover
E30 325 medium case 3.73 differential with 3 pressure disk
UUC Dual Shear Selector Rod
BWSport Reinforced urethane transmission set
Suspension
Triple adjustable ADVANCE DESIGN from GROUND CONTROL
GROUND CONTROL Front camber plates.
ELBACH springs : 247549 500.225.0700 (front) & 189633 600.250.0500 (rear)
BIMMERWORLD strut mounted adjustable swaybar links
IRELAND ENGINEERING subframe reinforcement kit Z3
Stainless steel rear shock tower reinforcement plate (5/32’’)
IRELAND ENGINEERING urethane bushings shock mount Z3
AKG bushings front control arm offset 95D
AKG rear subframe & differential mount 80A
AKG rear shock mount reinforcement plate
IRELAND ENGINEERING Posi-lock toe & camber kit (2)
POWERFLEX Rear Trailing Arm Bushing Set 95A
PEGASUS narrow Spherical Bearing, 1/2 x 1.0 (lower rear shox)
Brakes
ZIMMERMAN front E46 2001-2005 330i/ci/xi (325mmx25mm rotors) & calipers
PERFORMANCE FRICTION 06 pads 330i (2001-2005)
BREMBO rear disk & OEM Z3 rear caliper
GOODRIDGE stainless hoses
RACING BLUE DOT4 fluid
IRELAND ENGINEERING Delrin brake pedal bushing
PERFORMANCE FRICTION rear 08 pads Z3 2001
NOT INCLUDE +2000$
MASSIVE non-M e36/e46 332x32mm brake kit
WILWOOD SUPERLITE calipers, 4 pistons (1.38’’)
WILWOOD H Compound (dry) HAWK HT-10 (rain)
Wheels and tires
OEM e36 M3 Contour M, 17 x 8.5, rear1999 wheels , MICHELIN Super Sport Pilot (rain tire NEW) 245-45-17
BEYERN Black Mesh 17 x 8.5, 19 lbs, HANKOOK Ventus RS-3 245-40-17
VELOCITY MOTORSPORT 12mm (rear spacers)
BWSport 5mm (front spacer)
BIMMERWORLD Race bullet wheel stud kit (75mm front & 82mm rear)
Safety
MASSIVE BRAKE BMW 2002 floor & seat mount
2 COBRA Monaco pro seat
VAC floor mount adaptor (passenger)
Custom floor mount adaptor (driver)
Goodies
OEM Z3M Front bumper
50% Tinted windows
NEVER DONE GARAGE splitter & lower grill
HURST shifter
Custom M shift boot & E-brake boot
RAPTOR Shift light
Interior Carbon fiber trim kit
Roof railing Carbon Fiber 3M strip
CURT 1500lbs HITCH
SNOWBEAR utility trailer
UPGRADE – REPAIR LOG BOOK
May 2012
RACING BLUE brake oil, OEM Battery
August 2012
RUNAWAY tire (4)
BREMBO rear disk, OEM rear pads
PIONEER radio with Bluetooth, Tinted 50% windows, HID 6000 beam
November 2012 (1500$ including front Zimemrman rotors)
E46 330i M54 3.0l calipers rebuilt, Zimmerman rotors (325x25) (OEM Z3 are 300x22)
PERFORMANCE FRICTION 06 pads 330i (2001-2005), PERFORMANCE FRICTION rear 08 pads Z3 2001
CONTINENTAL strap
Removal of the AC system
OEM Water pump metal impleller, OEM thermostat housing, Prestone flush
OEM clutch fan, OEM fan blade, OEM fan cover
AKG engine mount, shifter, diff & rear subframe, front A-arm with offset bushing
GROUND CONTROL coilover suspension, camber plate + azote shock filling
Rear Toe & Camber adjustment kit
Rear subframe re-welding, Front subframe reinforcement weld,
Transmission REDLINE MTL
AVRIL 2013 (550$)
OEM E30 3.73 LSD rear differential medium case, M diff cover, new gasket, REDLINE 75w140 GL5
Résistance 1.7 -2 pour bancs
Racing Seat with VAC bracket
3.5’’ intake silicone
Brake line oil change, RBF-600
MAI 2013 (450$)
Oil change LIQUIMOLY 10w50 GT1 (45$/4l)
OEM S54 Oil cooler housing
OEM E46 M3 oil cooler w/shroud
OEM E46 M3 oil cooler hose
Race bullet wheel stud kit (75mm front & 82 rear)
BWSPORT reinforces urethane transmission mount
OEM transmission support
Narrow Spherical Bearing, 1/2 x 1.0
Strut mounted adjustable swaybar links
JUIN 2013 100$
GROUND CONTROL front shock rebuilt (factory)
ALIGNEMENT GARBIS race set-up
Degrease & powerwash
TO DO Aout 2013
SPAL fan kit
Install Headers
Marc124444 is offline   Reply With Quote
Old 08-20-2013, 01:18 PM   #2
Marc124444
UPDATE : 69574 miles
Inside pics :
Original seat also available if you don’t want the Cobra
