07-17-2013, 12:55 PM
Car: 325IS
What engine oil do you guys use for your daily darive S52? All year around?
Just did an engine swap, what do you guys use for your S52? It's gona be my DD and dealer only has 5W30 or 10W60, either one is ideal for S52.
I spent some time reading and searching, most ppl say they use 5w40, I'm thinking may be Mobile 1 5W40? I just want to konw what do most of you guys use? Considering I'm gona use it in winter and in GTA it gets around -15/-20 in winter.
Input are much appreciated!
07-17-2013, 01:01 PM
Car: E30 touring
I use 5w40 in my m50, I was using Rotella T (I think Rotella T6 to be exact) but now I have a source for LiquiMoly cheaper than the Rotella so I used that last oil change. No problems associated with the oil.
07-17-2013, 01:06 PM
Car: 325IS
CT has redline 5w40 and Walmart has Castrol Edge SPT 5W40 ..No luck with Mobile 1 so far..
07-17-2013, 01:12 PM
Car: M Coupe
I don't believe they make 5W40. Only 0W40 if I recall correctly.
07-17-2013, 01:13 PM
Car: M Coupe
Putting my 2 cents here...
What weight oil to use also depends on the condition of your engine too. If your engine has high mileage, you may not want to use lighter oil as oil consumption will be high due to worn piston rings. Know the oil pressure is good indicator but you will have to do some mods to get the reading (from start up to operating temperature).
I have a E36M3 and I believe the manual does say (have to double check) 5W30 is the standard oil. I did for the longest time until I switch to 5W40. Then again I stopped driving my M in the winter time.
07-17-2013, 01:33 PM
Vtec just kicked in
Car: 99 S52
0w30,0w40,5w30 ,5w40 is all fine pick your poison.
-||Old Crayons||-
07-17-2013, 02:12 PM
Car: M3
I try to stick with LL-01 approved oils.
Recently that included Castrol Edge 5W40, I've also used 5W40 Motul during track season and 0w30 German Castrol during winters.
07-17-2013, 02:22 PM
Car: 325IS
Thanks guys ! Castrol 5W40 it is.
07-17-2013, 06:50 PM
///M3
Car: Estoril M3
I have been using Liquimoly 5W40 during winter in Ottawa (-30)and summer time and it's good np at all.
so either Liquimoly or castrol 5W40 is good for your S52.
5W30 is fine too.
07-24-2013, 08:57 PM
#10
Car: 1997 E36 M3
I've been using Castrol Egde 5W40 for the last couple of years, including winters.
07-26-2013, 11:45 AM
#11
Car: e36 328is S/C'd
Mobil 1 0w-40! your car will love you long time
PREVIOUS CARS
07-26-2013, 03:05 PM
#12
Car: S52 e30/e90 330i
Shell Rotella T6 synthetic
10-16-2013, 12:47 AM
#13
BGDorcol
Car: 1998 328I M Sport
I'v been using Castrol Egde 5W40 for the last 7 years in my E36 as well. Great Oil.
10-19-2013, 08:52 AM
#14
Mobil1 0w-40 !
PREVIOUS CARS
Thread Tools |
Display Modes |
