Old 03-07-2013, 06:16 PM   #1
GTCobra
GTCobra's Avatar
Exclamation Crackiling in speakers 04 745li hmmm... Any suggestions on why??
So sometimes I get some crackiling in the speakers I could be wrong but sometimes I feel like it moves around to other speakers and at different volumes it will act different too... Sometimes a speaker will not produce sound at different volume levels
Any suggestions? I'm thinking of doing a speaker upgrade
If it ain't a V8 it ain't great
2002 Ford Exploder Eddi Bauer V8
1987 GT Cobra Tee Top's #297 of 300 V8
1996 Jeep Grand Cherokee Laredo V8
1995 Ford Taurus SHO V6 (not plated)
Not gunna put cars prev owned or sold, The screen wouldn't be able to fit em in
2004 BMW 745 Li V8
GTCobra is offline   Reply With Quote
Old 03-07-2013, 11:31 PM   #2
MANDD
Autobahn East
The Logic 7 amps fail quite often but will affect all low range speakers in the rear and under the front seats. If the optic receiver/driver is failing in the L7 amp it will affect the complete MOST bus.
The ASK will affect the high range speakers in front.
But first you need to do a light intensity test on the MOST bus to see which component is dropping out.
The easiest test is to loop out the most common failure items on the MOST bus one at a time such has.... DVD NAV, SVS module, and TCU. Reset the MOST bus and listen for presence of the crackling noise.
Use BMW 61 13 6 917 541 MOST fiber optic Loop.
The 4 modules listed including the L7 amp are in the trunk behind the left trim panel. The L7 amp if used is plug and play no coding necessary.
Mark.
Old 03-08-2013, 01:07 AM   #3
^^^Thats some pretty good info!
And after that, you can come see us for the parts needed!
Old 03-08-2013, 10:39 AM   #4
+1 to both above members!
Old 03-12-2013, 04:05 PM   #5
GTCobra
GTCobra's Avatar
What if I just simply replaced the AMP... I know of a write off 745 hanging around actually
2004 BMW 745 Li V8
Old 04-25-2013, 07:47 AM   #6
Mikey83
Mikey83's Avatar
Try that first,
If its the Subs L7 for sure, if fronts it could be just your ASK.
Ive had both sent out and repaired by a member on another site for $400 including shipping. PM if ya want details.
Current - 2011 E70 X5 3.5i
Sold
2003 745Li Titanium Sliver Metallic w/ Black Interior
21" OEM Style 128, Angel iBright V3 w/ Matching Fogs, H&R Springs, BTUM8000, LED Side/Front Markers, White Bulb Interior/License Plate,
Stealth Bulb Signals, 15mm Rear Spacers, ACS Style Roof and Trunk Spoilers, Debadged
Mikey83 is offline   Reply With Quote
Old 04-26-2013, 09:51 PM   #7
zzzreyes
just replace the L7 today, had the crackling noise, tested each component with the lollipop and were all good, not a hard swap, but you do have to have good lighting for the screws in the back!
zzzreyes is offline   Reply With Quote
Old 04-30-2013, 01:18 AM   #8
GTCobra
GTCobra's Avatar
Well it comes out of service this week so I'll have some tinker time soon
2004 BMW 745 Li V8
