Old 04-24-2013, 11:12 AM   #1
buzzdmonkey
Failed etest :(
alright guys well heres my problem. I went for an etest last night expecting to pass pretty well since i installed a brand new O2 sensor and had no more check engine light. but i noticed after the O2 sensor i have a decrease in power .
so what i failed(so the guy said) even though the sheet says (valid) next to the numbers on was Dilution Percent, it was supposed to be no higher than 6... mines at 14.06 at 2500 RPM and on idle its at 13.61 . i also failed on HC(ppm) whatever that is, the limit for that one is 200 and at 2500 rmp i got 67 so that passed but at idle i got 448! Captaine34 told me how to fix that. SO what i think the problem is is my CATs , i was driving for a while with a broken O2 sensor and i read on bmwe34.net that could have made carbon diposits in the CATs . so before i replace the CATs or make whole new exhaust i just want your guys opinion because im sure theres a few people who understand these numbers more than i do or have had the same problems Thanks in advance
buzzdmonkey is offline   Reply With Quote
Old 04-24-2013, 10:10 PM   #2
SamE30e
SamE30e's Avatar
HC Is hydrocarbons. It's unburned fuel, so either a misfire (which would be obvious) weak spark, bad compression, bad fuel spray pattern (pressure or clogged injector).
If the O2 was replaced then that shouldn't be the issue. Check the vacuum line to the fuel pressure regulator.
When were the plugs done last?
When was the air filter done last? Can you see light through it?
There's a few things that may help.
85 325 - Turbo M52B28.
Old 04-25-2013, 01:32 AM   #3
Change the oil too, contaminated oil can blow higher HC.
Old 04-25-2013, 10:41 AM   #4
captain E34
Sliding Sideways
captain E34's Avatar
give your car a vacume leak and it will lean out ur a/f ration.... you should pass then
__________________________
1988 535i M30 (Turbo Build)
1989 535i M30 (Beater)
1994 525it M50 (Beater)
2005 X5 M64 (Daily)
2009 335i (Daily)
The Rest Is History...
Old 04-25-2013, 08:24 PM   #5
buzzdmonkey
passed!
Old 04-25-2013, 08:25 PM   #6
captain E34
Sliding Sideways
Vac leaks, and a chill etester, is a guarenteeeeeed pass
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 04-25-2013, 08:59 PM   #7
Barnsdale
Barnsdale's Avatar
What did you have to do to pass?
Old 04-25-2013, 10:35 PM   #8
buzzdmonkey
Well I made a vacuum leak so it runs richer . Or more lean I can't remember haha . Captaine34 will let you know. But the real reason I passed was cuz I told the guy it was my second time so he made me pass
Old 04-26-2013, 11:02 AM   #9
bmwconnect
BMW Tuner
bmwconnect's Avatar
Running lean will not help, In fact it will drive up readings and fail badly . Running at 14.7 which is stoich for regular gas is the best way to pass
Old 04-26-2013, 11:19 AM   #10
Robb
EX E30 M3 Owner
Robb's Avatar
A vacuum leak will make it run more rich. More air = more fuel.
Old 04-26-2013, 11:22 AM   #11
captain E34
Sliding Sideways
The problem wit my car and buzzedmonkeys car was that with x amount of air being measured to much fuel was being delivered... small vac, un measured of course, leans out the air/fuel ration and made both out vehicels pass wether or not its supposed to make it fail... they both passed
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 04-26-2013, 11:44 AM   #12
Nah, the leak will be unregistered to the ECU. So the additional air isn't offset by the ECU as additional fuel: leaner.
Old 04-26-2013, 11:56 AM   #13
captain E34
Sliding Sideways
exactly and i have the etests to prove it
first one went to see if it would pass as is..... fail..
second one, swapped o2 sensor..... still fail....
thrid one i found a vac leak, and repaired it...failed worse!!...
Last estest, made the vac leak larger... PASS!
2005 X5 M64 (Daily)
2009 335i (Daily)
Old 04-26-2013, 11:59 AM   #14
Did you find that technique in the brochure "My Vehicle Didn't Pass the Drive Clean Test"? LOL.. page 3, in case of home made turbo system, induce vacuum leak.
Old 04-26-2013, 12:00 PM   #15
captain E34
Sliding Sideways
page 3, paragraph 4 most helpfull book ever writen
2005 X5 M64 (Daily)
2009 335i (Daily)
