Welcome to!
Old 04-22-2013, 08:22 PM   #1
e36 Oil temperature gage .
Hi to everybody. Does anyony know how to make an oil temperature gage work on e36?. What I have done is a complete drive train swap ( with harness and cluster all from the same car) from e36 M3(US) into my e36 328is and Oil temperature on M3 cluster still shows fuel consumption.
bokan is offline   Reply With Quote
Old 04-22-2013, 09:48 PM   #2
Techno Viking
Steve30's Avatar
you need an oil temp sender. the euro oil filter housing has one or you can run a sender from the drain plug. You wire the oil temp sender to the pin 13 on the connector X13 that goes into your instrument cluster. The pin is free so you don't have to cut anything.
E36 ///M3 S54
STock 335i
