Old 09-20-2012, 09:59 PM   #16
matty.dc
matty.dc's Avatar
Upgraded Parts
As asked here is a small list of parts that you could change up to if desired for added performance:
Pistons
Wiseco 10.5:1 C/R(stock): $780CAD - http://www.turnermotorsport.com/p-40...iston-set.aspx
CP Different C/R's : $1049USD - http://store.vacmotorsports.com/cp-p...kit-p2030.aspx
Cams
Schrick - $1089-$1399 - http://store.vacmotorsports.com/cams...rick-c163.aspx
VAC - $1499 - http://store.vacmotorsports.com/vac-...272-p1432.aspx
2013 Ford Edge - Daily Driver
Old 09-20-2012, 10:15 PM   #17
matty.dc
matty.dc's Avatar
OBD I Swap
Since I'm waiting for parts I will start on the different mods that are required for the OBD I swap:
OBD I Single Vanos Wire Harness
OBD I Sensors- Cam position sensor, crank position sensor(front of timing cover), Vanos solenoid(can use OBD II solenoid but the harness must be extended), Air intake sensor, Idle control valve (can use OBD II as well), OBD I MAF or HFM.
OBD I or II Ignition Coils - you have to modify the top of the valve cover to allow the coil wires to pass through nicely.
Silver Label 413 DME(EWS) or Red Label 413 DME(non-EWS)
M50 Manifold with throttle body and throttle position sensor.
--Feel free to add anything if you don't see it here.
21.5lb injectors (if you don't have an M3 or 328)
Chip required to run S52 OBD I system:
Red Label 413
TRM - $250 - http://www.racersmarket.net/index.ph...mart&Itemid=93
Turner - $250 - http://www.turnermotorsport.com/p-13...injectors.aspx
For the Silver Label 413 DME you need to buy the Turner chip with the EWS delete.
Upgraded Parts For Swap
--24lb injectors (if you have upgraded cams)
--540 HFM
--Chip to sustain 2 above mods(Turner or TRM Chip can both be custom set)
Old 09-21-2012, 11:10 AM   #18
sb_600
sb_600's Avatar
Red Label 413
Or talk to Barrie from Midnight Tuning (PM bmwconnect)! He'll set you up nicely with a custom tune.
Shawn
Old 09-21-2012, 04:56 PM   #19
matty.dc
matty.dc's Avatar
Do you know what he charges? Post it up
Old 09-21-2012, 07:53 PM   #20
team_ottawa
team_ottawa's Avatar
Nice build thread. Good job man
stance is everything
<img src=http://i735.photobucket.com/albums/ww359/team_ottawa/pic5.jpg border=0 alt= />
team_ottawa is offline   Reply With Quote
Old 09-21-2012, 09:45 PM   #21
egye30
egye30's Avatar
Ive got a good 413 red label if you still need one
Old 09-21-2012, 10:05 PM   #22
matty.dc
matty.dc's Avatar
Ive got both a red label and a silver label
Old 09-22-2012, 09:09 PM   #23
matty.dc
matty.dc's Avatar
Tear down
Today, I bagged and labelled all of the hardware since the block has to be bare bones to go for the bore.
Contents of bags
-Main Bearings, bolts, oil squirter and caps (labelled #1-#7)
-Front timing cover harware
-Oil Pump bolts
-Oil pan and baffle bolts
-Rear main seal housing hardware
-Additional hardware (hoarded from the junk yard)
-When removing the top of the main bearings (block side), make sure to note the direction of the tabs (picture 1) and also make sure that the piston oil squirters don't fall out(picture 4).
-Pictures 2 and 3 are just pictures to remind me at the end of the build where all of the different sized bolts go.
Old 04-17-2013, 09:29 PM   #24
Hey I saw on the cruise thread you were wanting to break in the motor before the spring cruise -- hows the project coming?
Old 04-17-2013, 09:49 PM   #25
matty.dc
matty.dc's Avatar
Well here you go! The motor is in and now has about 200km on it. With the engine covers, I wanted a little bit of a different look so I did them graphite (same colour as my wheels).
Old 04-21-2013, 08:41 PM   #26
uber e36
uber e36's Avatar
Noob question:
When rebuilding, do you always need to swap to new, larger, pistons?
Can't you just replace bearings, seals, etc?
'95 325is
?02 C4S
Old 04-21-2013, 10:11 PM   #27
kruler
Did this build thread go from bagging parts to having the motor in and painting engine covers?
kruler is offline   Reply With Quote
Old 04-22-2013, 07:21 AM   #28
matty.dc
matty.dc's Avatar
Originally Posted by uber e36 View Post
Noob question:
Not always. It's really dependant on the wear in the cylinder. In my case it was quite severe so I went as big as I could.
Old 04-22-2013, 07:21 AM   #29
matty.dc
matty.dc's Avatar
Yes it did lol. I will ffinish itvwhen I have some free time.
