Old 11-11-2012, 07:17 PM   #1
BMe30
all by chance...
BMe30's Avatar
Water under batt tray in trunk...
I drained the water from that plug under the car... When i removed the battery to dry the remaining water i noticed that there was a tube connected to the drain plug.. But where does this connect to?
Any ideas?
Gone but not forgotten
Old 11-11-2012, 07:18 PM   #2
It's supposed to be for that overflow port on the side of the battery.
Old 11-11-2012, 08:53 PM   #3
BMe30
all by chance...
BMe30's Avatar
Any idea where that water is coming from that stands under the batt tray?
Old 11-11-2012, 08:59 PM   #4
BmW1819
Sunroof drain?? That looks like the battery vent hose
Old 11-11-2012, 09:39 PM   #5
BMe30
all by chance...
BMe30's Avatar
How can i check if it is the sunroof drain?
Old 11-11-2012, 11:23 PM   #6
frankie591
open your sunroof and pour some water down the back drain and see if it leaks into the battery tray. Could also be a leaky taillight gasket, or there is a grommet above the battery tray where your sidemarker light wire exits the car.
Old 11-12-2012, 12:32 AM   #7
BMe30
all by chance...
BMe30's Avatar
^^^ thanks.. Ill give it a try
Old 11-12-2012, 04:36 PM   #8
Slowered318
Might be the flap vent from the trunk to inside the rear bumper, thats where the sunroof drain should be if it's connected properly. It could also be your trunk seal, mine leaks a bit into the battery area when I wash the car or park nose down in the driveway.
Old 11-15-2012, 08:49 PM   #9
BmW1819
Sun roof drains is a black hose that goes into that vent behind the bumper
Old 11-15-2012, 09:08 PM   #10
BMe30
all by chance...
BMe30's Avatar
Thanks for all the info!
Im going to do some water tests this weekend after i fix my oil leak by the oil filter canister and the block. Very common on the m42 it seems
Old 11-15-2012, 09:25 PM   #11
nonlocal
Last of the Late-Brakers
nonlocal's Avatar
Connect the battery vent too! Acid from an unvented battery will rust your shit faster than a puddle of water ever would...
nonlocal is offline   Reply With Quote
Old 04-04-2013, 09:32 AM   #12
BMe30
all by chance...
BMe30's Avatar
So it turned out to be the gasket around the passenger side rear tail light. It wasn't seated properly.
Old 04-10-2013, 08:09 PM   #13
BmW1819
Nice u silcone it?
Old 04-10-2013, 08:58 PM   #14
BMe30
all by chance...
BMe30's Avatar
Originally Posted by BmW1819 View Post
Nice u silcone it?
No.. The rubber seal around the tail light was not seated properly. I reinstalled the rubber properly and took care when reinstalling the tail light to the car. Did a leak test with my hose and it was dry. The past few days i left my car out in he rain... So far atill dry
Old 04-11-2013, 08:10 PM   #15
BmW1819
Ahhh nice
