Thread Tools Rating: Thread Rating: 59 votes, 5.00 average. Display Modes
Old 02-11-2013, 02:01 PM   #1276
Originally Posted by rev run d View Post
wondering if 15x8+25 and/or staggered 15x8 +25 15x9 +15 on 89 e30 will fit. Also recommended tire size?
3-5mm front spacer needed with most suspensions. For staggered I'd suggest 15mm front spacers and a 205/50 225/45 tire stagger.
Old 02-11-2013, 02:13 PM   #1277
fsiddiqui89
Awesomee thanks for the reply
Sent from my SGH-I717M using Tapatalk 2
fsiddiqui89 is offline   Reply With Quote
Old 02-12-2013, 12:47 AM   #1278
rev run d
Thanks! So you'd run 205/50 15x8 +25 w/15mm spacer F and 225/45 15x9 +15 R?
rev run d is offline   Reply With Quote
Old 02-13-2013, 10:59 PM   #1279
BMWe30Mstyle
Send a message via AIM to BMWe30Mstyle
Fit stock 1988 325ix?
15"x7.5" ET37
225/50/15 Front
235/50/15 Rear
BMWe30Mstyle is offline   Reply With Quote
Old 02-16-2013, 10:33 AM   #1280
I change my mind. The rears will be tough to fit and there's really only track tires available in that size.
195/50 front 205/50 rear, everything else the same. Dead flush front and rear and won't rub.
Old 02-16-2013, 10:35 AM   #1281
15"x7.5" ET37
225/50/15 Front
235/50/15 Rear
Fronts may require a 3-5mm spacer depending on how wide the tires run. And if you're mentioning 235/50 the only tire available afaik is the R888 semi slick and they definitely run wide.
Old 02-22-2013, 07:00 PM   #1282
E30DOOD
volks
I have a set of volk EVO III wheels 18"x8/9 +45 in a 4x100 pattern. What are the chances of the fitting without rebarrelling?
E30DOOD is offline   Reply With Quote
Old 02-25-2013, 12:43 PM   #1283
Needs 20mm spacers F/R to work.
Old 03-06-2013, 02:04 PM   #1284
sacroyalty
Is the offset too high?
Hello, im looking at some R1 rims online, and was wondering if the offset was too high? I have some small spacers (5mm) and extended lugs ready to go. I know the problem is usually in the front, not sure if 7" wide with +37mm offset would clear?
Thanks in advance.
Details
Rim: R1
Bolt Pattern: 4x100/114.3
Offset: +37mm
Finish: Black/Polished Lip
Center Bore: 73.1mm
Material: Aluminum
_____________________________
Bruce Hamilton
California State University Fresno
Image and video hosting by TinyPic
sacroyalty is offline   Reply With Quote
Old 03-06-2013, 04:16 PM   #1285
You'll want 20mm spacers and extended bolts all around to fit those. May want to look into wheels that are in the correct offset range (+15 to +25 as a rough guide).
Old 03-06-2013, 04:24 PM   #1286
sacroyalty
That's what I thought. Thanks for the quick reply!
Bruce Hamilton
Old 03-13-2013, 07:48 PM   #1287
RLTW86
Sua Sponte
RLTW86's Avatar
Just picked up some RPF1's
Just got some RPF1's. They are 16x8 with a 38 offset. I'd like to run 225 tires but I will probably go 205 and stretch them. I have a 1990 325is, lowered with Bilstein shocks and HR springs. Just wondering what you recommend for spacers and tire size.
Cheers
They make vehicles with four wheels?!?! Let's try that out! . . .
RLTW86 is offline   Reply With Quote
Old 03-14-2013, 11:31 AM   #1288
Cheers
For 225/45/16s use 15mm spacers all around.
If you stretch 205/45/16s, you can use 20mm F 25mm R and it will have a flush look.
Old 03-14-2013, 12:14 PM   #1289
RLTW86
Sua Sponte
RLTW86's Avatar
Thanks man!
Old 03-18-2013, 04:12 PM   #1290
MBGold
I need advice to fit a 16" wheel on my 318is.
What are the offsets to have the wheel right below the fender (i don't want the tire to stick out of the car), both front and rear with 205/50/16 tires and no spacers, no rubbing.
Please check is this accurate:
16x7 front ET20?
16x8 rear Et15?
or
16x8 front ET?
16x8 rear ET15?
I wanted a XXR 501 wheels but i don't find 16x7 on market.
Thanks,
MB
MBGold is offline   Reply With Quote
