Originally Posted by ZERO NERO
How do you think this set up would work with a 305 or even better 315 tire at the back on a e31 ? do you think it might need some roll?
It'll fit, I wouldn't do that wide at the back if I was you thou, if anything you may need 5-8mm spacers to space them out, the tires may require rolling at the back, but if you stick with say 285/30/19 at the back you will be golden.
