Old 02-11-2013, 10:43 PM   #16
e36francis
Originally Posted by DET1990 View Post
partsource will scan codes for free if they have partsource in montreal they should
Unfortunately we don't have Partsource in Quebec... I'll look for something similar though! Thanks!
e36francis is offline   Reply With Quote
Old 02-11-2013, 10:46 PM   #17
e36francis
Crank Sensor
Originally Posted by propr'one View Post
Crankshaft sensor or camshaft sensor, or wiring between the two (which was recalled on m52's)
Didn't know there was a recall for that wiring, good to know! I'll definitely take a look at these sensors this weekend!
Thanks,
Francis
Old 02-20-2013, 08:19 AM   #18
e36francis
Hey guys,
So I haven't found anyone to scan my car, I am therefore looking into buying the equipment to do so myself. Can anyone point me in the right direction as to what I need to buy and from what site/place so I can do it myself?
Thanks,
Francis
Old 02-20-2013, 08:42 AM   #19
DET1990
I use the peake research fcX
Google peake research
DET1990 is online now   Reply With Quote
Old 03-10-2013, 09:40 PM   #20
e36francis
Hey guys,
Thought I'd post an update in case anyone searches this thread later on.
Two weeks ago, I finally got the car scanned, and it turned out to be an oxygen sensor (code P0155 - Bank 2, sensor 1). So I started shopping around for a replacement, looking at an inexpensive alternative to the Bosch one. While doing so, a friend and I decided my car deserved to be heard without a muffler. So we cut the muffler off, and on the test drive I could redline normally (why? I don't know). Check engine light was still on though. Ran straight pipes for a week, then decided to put it back to my M3 setup (had to keep looking left and right for cops, damn it was loud). Anyways, I'm back to my old setup and I can still rev to 6500 rpm, and even beyond. Check engine light still showing. I am still going to change the oxygen sensor, but I can't figure out what happened for my car to go back to normal.
Thanks a lot for your replies guys, appreciated your help!
Francis
Old 03-30-2013, 12:30 PM   #21
DET1990
Lol I changed my diff yesterday to a 323, and I was driving with the muffler off and now mine is doing the same thing peake tool is giving me vehicle speed sensor code so I'm gonna swap over my speed sensor from my old diff and see if that fixes it. When I clear the codes it let's me rev all the way but once it comes back same thing.
Old 03-30-2013, 05:10 PM   #22
DET1990
I changed the speed sensor and its still has low rev limit also has abs light if that has anyy thing to do with it
its actually vehicle speed signal not present code d6 on peake tool the speedometer does work
Old 03-30-2013, 07:12 PM   #23
poolays
poolays's Avatar
I've seen a plugged catalytic converter cause
Similar issues. I'd look there considering you
Have a code for that issue
poolays is online now   Reply With Quote
Old 03-30-2013, 07:14 PM   #24
poolays
poolays's Avatar
The catalytic converter is probabally all emptied into that muffler causing a restriction
Old 03-30-2013, 07:15 PM   #25
DET1990
I don't have a code for that issue that was the other guy who started the thread, but I'm going to check the abs sensor as another member told me that could cause this issue
Old 04-02-2013, 11:31 AM   #26
bAhN_BurNUR
bAhN_BurNUR's Avatar
I have the same problem as well in my 97 328i. I did a scan not to long ago and and got a code 214 (P0500) which is related to the VSS vehicle speed sensor. I believe it to be in the passenger back wheel area. I have not got a new VSS but, before I do I would like to know if that could be the culprit. Car pulls good to, and then limits to 5250RPM
bAhN_BurNUR is offline   Reply With Quote
Old 04-02-2013, 12:03 PM   #27
DET1990
The vehicle speed sensor is In the differential
Tags
328i, e36, problem, redline
