Old 02-15-2013, 04:35 PM   #1
lmac2020
2010 328 ix - engine sound on highway
Hello,
I just purchased a used 328ix and I LOVE this car. There is one issue - but I don't know if it is a "problem" or just normal for this vehicle.
Below 80 km an hour the engine is quiet - perfect. On the highway, at 80 and above, the engine is not quiet. I would describe similar to when you have a manual transmission, right before you gear up (when the RPMs go higher and you know you need to gear up).
So far the dealer says they aren't hearing anything, but I'm not sure if this is really normal.
Any thoughts?
Thanks for your feedback!
lmac2020 is offline   Reply With Quote
Old 02-15-2013, 04:50 PM   #2
damameke
Originally Posted by lmac2020 View Post
There is one issue - but I don't know if it is a "problem" or just normal for this vehicle.!
I would ask the dealer for a test drive of the same car as yours, so you can compare if it is normal...or a problem..
Old 02-15-2013, 07:06 PM   #3
lmac2020
Good idea
Thank you for replying. I'll do that.
Old 02-17-2013, 08:40 PM   #4
TSI
Reverse Gear Member
Do the revs also go up, or just noise?
Old 02-18-2013, 04:14 AM   #5
davericher20
black and blue
davericher20's Avatar
What are the rpms at when it starts to get loud?
Old 02-18-2013, 10:30 AM   #6
lmac2020
The sound seems at a constant level. I will check the rpms (I should have thought to do so -thanks). The service guys found two of the tire rims are bent, so they are replacing them. As soon as the car is ready we'll check out the rpms.
Thanks for your replies.
Tags
328ix engine, automatic, loud on highway
