Old 01-22-2013, 10:11 PM   #1
Marky_mark
Detailing Specialist
Marky_mark's Avatar
Send a message via MSN to Marky_mark
Drivers side heated seat problem
Hello maxbimmer
As my tiltle states I have a problem with my driver side heated seat.
So the problem is this when you get into the car when its cold like first thing in the morning start the car up get ready to go and push the button to turn on the heated seat and it shuts off right away and if you push it again same thing it shuts off. Now after I have been driving and the car is warmed up and you push the button to turn on the heated seat it works and stays on like it would normaly work. So I have been doing some resarch on this problem and my guess is it could be the switch in the center consloe that needs to be replaced but I could be wrong and I don't want to just throw parts at this problem and not fix it so if anyone can give me some ideas or tips that would be great.
Mark
Marky_mark is offline   Reply With Quote
Old 01-27-2013, 02:10 PM   #2
Lercs
Lercs's Avatar
try swapping the drivers side switch with the passenger side switch.
If that solves the problem, then get a new switch.
Follow 8legs Racing on Twitter and Facebook
@8legsracing
www.facebook.com/8legsRacing
Lercs is offline   Reply With Quote
Old 01-30-2013, 09:26 AM   #3
Dinanstu
I LOVE logic..!
Old 01-30-2013, 12:26 PM   #4
It won't work, as the switch is one unit, not left and right...
Old 01-30-2013, 02:36 PM   #5
Dinanstu
Go woth Eurostyles advice - they do this all day long. I was thinking E36....
Old 01-30-2013, 06:45 PM   #6
I am in the same boat with my M5 and happens on both seats, tried changing the switch but it did not solve anything! Had no time to investigate as it never gets driven in the cold...Let us know if you find the solution!
Old 01-30-2013, 10:36 PM   #7
starbuck
Having the same issue on driver seat for 2 months now on my 2000 323i. It keeps shutting off until the car warms up and then it will stay on.. Defeats the purpose of having heated seats if it only works when the car is warm.. Passenger seat works fine
starbuck is offline   Reply With Quote
Old 01-31-2013, 08:46 AM   #8
Dinanstu
On my E36, it was a short in the heating pad itself that had to be replaced, but it never came on when it warmed up. I would guess its a wiring issue that is affected by heat (expansion) and probably at a wiring connection. The drivers side is also the most used, so the first to wear out. I would check out a wiring schematic and see where this common fault could be.
Fault monitoring
The electronic seat heating control system monitors the temperature sensor and heating mats for faults. Detected faults are stored in the fault code memory of the centre console switch centre.
The following faults can be recognized:
Short-circuit or line break
Short-circuit or line break of temperature sensors
Break in heating mats
If a break or short occurs at the temperature sensor, the seat heating is switched off in order to prevent overheating. The function LEDs are switched off.
I couldn't view this schematic for the E39, maybe you'll have better luck..
http://www.bmw-planet.com/diagrams/r...9new/index.htm
