Go Back   maXbimmer Forums > Specific Regional Topics > Quebec/Gatineau/Ottawa
Old 11-25-2012, 10:04 PM   #391
North
Any reason you went to steel fenders instead of composite? You've already done a decent amount and seemed like you were going to do it before to replace the old ones.
And I hope by having obd1 stuff to figure out you meant you had to convert your harness to work with the obd2 motor.
Especially since this:http://www.r3vlimited.com/board/showthread.php?t=230879
Plus the higher resolution of fuel/timing maps because of the more powerful DME and the ability to more easily tune/pull codes.
North is offline   Reply With Quote
Old 11-26-2012, 06:28 AM   #392
Chris916
Chris916's Avatar
Yea I was never super happy with the fiberglass fender i made last year. They looked good from far and did the job, however, i think i can get a better result from steel. They will be much more sturdy as well. I may make a mold of them after if they turn out nice, and if i have time. That way I can make some fiberglass fenders as well.
I did the obd1 conversion by using an m50 obd1 harness with all obd1 sensors. For my application, this was the quickest/easiest way to go. It is also a much simpler system with less crap to deal with in the engine bay.
1991 318is - My Track Car Build
Chris916 is offline   Reply With Quote
Old 01-20-2013, 06:14 PM   #393
Chris916
Chris916's Avatar
Small update. Haven't done much lately, but it's time I start cracking down.
Front Fenders are Pretty much done. Not too sure if i'm going to be doing the rears. It's a lot of work, and I have a lot of other work to get done that is more important. Ill leave it until the end then decide if it's worth it.
Also got the motor out today. I decided to cut out the front core/rad support to simplify engine removal/install. It makes it so much easier to pull it straight out instead of constantly fighting with the leveler.
I also want to push the rad a bit more forward to free up a bit of space in front of the engine. The plan is to build a custom removable core support for this.
Old 01-20-2013, 09:52 PM   #394
DIY
Permanently Dirty
DIY's Avatar
thats awesome! I'll be watching with interest. I've been thinking about doing the same thing so I can make a shroud that vents out the hood
Old 01-21-2013, 09:51 PM   #395
Why don't you just tube chassis the front end? Make a removable front structure that sits on top of it!
Old 01-22-2013, 12:41 PM   #396
Kudos on the front clip removal that motor will slip right in
Old 01-22-2013, 12:46 PM   #397
There's a wicked 2002 build on r3v iirc in which he build a smart removable front clip, should check it out.
http://www.r3vlimited.com/board/show...ip#post3403092
Warning, you will feel inadequate, lazy and stupid after reading this thread. At least I did.
Old 01-22-2013, 04:40 PM   #398
Chris916
Chris916's Avatar
Haha waaayyy too much work for minimal gain. Would be cool though.
Very cool build! Definitely not going into too much detail. Most likely will be just some square tubing with some tabs to hold the front end together.
Old 01-22-2013, 04:45 PM   #399
Did you see the trailer hitch just above that. I love that guy no homo.
Old 01-22-2013, 05:33 PM   #400
Chris916
Chris916's Avatar
Haha yea so classy. I wish i had the time/dedication to take on a project like that. Would love to build a 2002 some day.
Old 01-23-2013, 01:06 PM   #401
bmwconnect
BMW Tuner
bmwconnect's Avatar
your a machine Chris
Old 01-23-2013, 01:29 PM   #402
dude you're making me look like a slacker....
oh wait...
yeah I guess I really should get started - hell the car is still in the trailer from my last event LOL
Old 01-23-2013, 10:22 PM   #403
oh wait...
Your poor car Hope theres coolant in there!
Old 01-24-2013, 11:19 AM   #404
haha yup - just after i posted that I realized I lied - it's been "winterized"
IE: water replaced with coolant and battery pulled.
Hopefully will be getting it in the garage this weekend... we'll see!
Old 02-03-2013, 04:36 PM   #405
Chris916
Chris916's Avatar
So the front clip is almost done. Still need to weld on a bunch of tabs to hold the lights, grills and kidney's on, but for the most part, im pretty happy with how it is turning out.
Mounting points:
Rad mounted on:
I dropped the rad about 2" from the stock location and moved it forward about 2". This will give me enough space to install the spal puller behind it with a bit of room to spare.
The great thing is, the stock core support weighed 9lbs and this one is now at 8lbs. Just a good feeling knowing im not adding weight to the car!
