Old 11-22-2012, 07:17 PM   #1
kreso
Question squeaky driver window
Hey guys, so I'm assuming I over tightened when I replaced my driver side lock actuator. Every time it rains or i wash my car its squeaky going up and down because the water seems to get trapped inside the door(no water is on the inside of the car, just outside part of glass). after a rainy day, the next day when I roll down the window and roll it back up only the driver side comes back up wet, with the rubber squeaking. If anyone has any experience with the actuator replacement, let me know please, thanks.
kreso is offline   Reply With Quote
Old 12-21-2012, 11:59 AM   #2
kreso
anyone
anything?
Old 12-21-2012, 12:36 PM   #3
Blackedout95
Squeaking where exactly?
Try using some oil in the window runners to start, spray generously and put window up and down to lube. We do this as part of our general service too since these windows like to squak and get dry. Be sure to put the nozzle tube into the runner and go up and down, the back and small portion before the side mirror. You may see some streaking along the window edge but thats cool, it will go away or you can clean it off, your choice.
E46
Old 01-29-2013, 04:30 PM   #4
kreso
What kind of oil? Also would it be possible that I over torqued the screws into the inner side panel of the driver door? My window buttons control box on the door seemed tighter than before I took it apart, so I loosened it until it wasn't squished looking but I guess I could loosen them up some more, I believe theres 3 or 4 screws behind the door trim, just not sure if that can affect the glass.
