Old 11-30-2012, 04:02 PM   #16
most probably a secondary problem. sometimes one masks the other. T-state stuck open would just make the car run cool. temp gauge would be low. Clutch fan wouldn't engage properly. completely unrelated to engine revs moving up. the car even under cold start only increases engine revs slightly until the the car gets warm and the revs drop to normal 700prm. My car revs between 1600-2000k - with the car running rich. I suspect it's the AFM since when I unplug it the revs drop to normal with some sputtering to compensate for air/fuel adjustment. Car should stall when unplugged or very close to stalling. This isn't happening.
Old 11-30-2012, 05:13 PM   #17
TSI
Reverse Gear Member
Fair enough. Assuming all vacuum lines are good, I'm out of ideas.
Old 12-04-2012, 02:02 AM   #18
RedEye
Hater of Previous Owners
Could be the coolant temp sensor (the one that feeds the ecu, not the gauge. The blue one iirc). After I fixed all my vacuum leaks the surging stopped but the car was running so rich it wouldn't warm start. The resistance of that sensor increases as temperature decreases; the sensor's internal resistance also increases with age and wear. So an aging sensor can be telling the ecu that the engine is a lot colder than it really is, hence running rich. When I got my car I think it was only running because the vast amount of unmetered air from the many vacuum leaks sort of balanced the vast amount of extra fuel from the dead CTS.
RedEye is offline   Reply With Quote
Old 12-04-2012, 09:33 AM   #19
I do remember swapping that some time back with a used one. that does seem to make sense. it is running rich for sure. Well, that may need swapping out for a new one. However, the sensor is brass and the only resistance it could bring with it is the tarnish? that can easily be cleaned up with a wire wheel. I think the sensor is like 15.00 -20.00 at most. Worth a try. thanks for the input.
Old 12-10-2012, 03:05 PM   #20
RedEye
Cleaning didn't help mine, but yours might not be as far gone. I really hate working on engine electrical on these cars, the wiring seems so brittle with age I keep expecting the whole harness to shatter every time I touch it.
Old 01-07-2013, 01:29 PM   #21
Barry
Well the surge is gone , now it just doesn't want to idle when it is cold. I have replaced the ICV and it made no difference. I have a code that read ICV. Check engine light is on except under heavy acceleration. then it feels like a little back fire and the light is on again.
So my question is could the throttle positioning switch be pouched??? I am really at wits end with this issue. Any thoughts would be appreciated.
Barry is offline   Reply With Quote
Old 01-07-2013, 05:17 PM   #22
Dinanstu
http://www.pelicanparts.com/bmw/tech...leshooting.htm
Old 01-07-2013, 06:54 PM   #23
Barry
Thanks I will check the tps tomorrow
Old 01-09-2013, 05:22 PM   #24
Barry
Throttle Positioning Switch is pouched. No continueity between 2 and 18
Old 01-12-2013, 12:36 PM   #25
Barry
So I have replaced the TPS and I have a beautiful idle and responce from the engine. Why does the check engine light keep doing the on /off thing?????? This is behound frustrating. The code still reads ICV, could this be associated to the 02 sensor? I am reaching for anything at this point.
Old 01-18-2013, 08:33 PM   #26
Barry
I took a stab in the dark and replaced the computer. Bingo light went out. Now I am getting a back fire once and awhile when I am coming off the gas, Check Engine light flickers. Any ideas what might cause that?????
