Old 11-26-2012, 07:13 PM   #1
325ixE30
325ixE30's Avatar
Slow Drain on Battery
Hi All,
I dont drive my car too often (live/work downtown) sometimes maybe once a week, sometimes less. About a month ago I replaced my battery. It was tested and they said it was gone, but weren't specific.
I bought a new battery and everything was fine as long as I drove it once a week.
I went to go start it tonight and the battery doesn't have enough to crank the engine, but has enough to work the radio and interior lights.
Very similar to what happened before I replaced my old battery.
My old battery wouldn't even start the car with jumper cables hooked up to another car.
I've checked all the interior/trunk lights to make sure nothing has been left on, but have found nothing.
Has anyone experienced this? Could it be the alternator?
325ixE30 is offline   Reply With Quote
Old 11-26-2012, 07:54 PM   #2
adam325i
adam325i's Avatar
Soon as you got your new battery did you put it on a long slow charge before using it?
90 325i 4dr Winter fun
90 325i 2dr Summer/track car
87 325i 4dr Parts
adam325i is online now   Reply With Quote
Old 11-26-2012, 08:14 PM   #3
noid
noid's Avatar
Are you sure it is your battery and not your starter? More specifically your ground that allows for your starter to ground? To test this, take your negative jumper cable and clamp one end to the oil train plug and the other then to the steering rack.
I have had an alternator in my old e30 that would charge but not fast enough if at/around idle. To test this take a volt meter and check the voltage at your power lead at your battery while the car is on, you should see over 13v. It could possible that a diode has gone bad and it is drawing power even when the ignition is off. Thankfully Canadian tire tests alternators for free.
Have you checked the trunk light, glove box, trunk, and interior lights?
Other things to suspect:
Bad relays
Pinched wires
Also see this thread:
http://forums.pelicanparts.com/porsc...s-battery.html
noid is online now   Reply With Quote
Old 11-27-2012, 02:30 AM   #4
325ixE30
325ixE30's Avatar
Got it fully charged and checked before I left the store.
Old 11-27-2012, 02:33 AM   #5
325ixE30
325ixE30's Avatar
Bad relays
Pinched wires
Its not the starter. Unfortunately I don't have any electronic testing devices.
The first thing I double and triple checked were all the interior/trunk/glove box lights.
Old 11-27-2012, 12:38 PM   #6
Get a $20 multimeter -- it will make this process a lot simpler
It doesn't crank when boosted? Even when left to charge for a bit?
It could just be your alternator going slowly as mentioned... Or your battery draining slowly...
Try to get it started (roll start, jump, etc) and meter the battery. You'll be able to rule in / out alternator right away if the volts are staying constant or dropping.
When it's even running for a bit and then is shut off, meter again to check if your battery is holding charge.
May be worth investing in an on-car trickle charger to keep your battery nice when it's sitting for periods like that
Old 11-28-2012, 08:39 PM   #7
I use a Battery Tender on my e30 that sits for days or weeks (or in the winter, months) and have had excellent success keeping the battery healthy that way.
Old 11-28-2012, 09:05 PM   #8
325ixE30
325ixE30's Avatar
I haven't tried to boost it with the new battery, but the old one did not crank even when left connected to the other car for 10 mins.
I'm going to take the battery in to where I bought it to get checked out and charged, but will need to give it a boost to get it there - lol!
:o(
Old 11-28-2012, 10:33 PM   #9
TSI
Reverse...
Where are you located? I might be able to give you a hand with that...
