Old 11-02-2012, 07:03 PM   #16
richie_s999
also check the diff bolt, sub frame mounting points on M3's are reinforced from the factory, so shouldn't be torn, if they are I wish you luck, I tore them right outa my e36, was a hell of a job welding them back in and welding on the M3 reinforcement plates, but it was an excuse to upgrade all the bushings when I had it apart
Old 11-02-2012, 10:39 PM   #17
dcramer
I just put a new diff in the car, so the bolt is good.
I'll let you know what I find after I pull it apart.
Old 11-02-2012, 11:20 PM   #18
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Exhaust hanger rubber weak from years of heat exposure. Mine got so bad that they broke the seal on the midpipe. Just figured it out the other day. They get too soft laterally and the muffler bangs around in the tunnel. Easy way to check, see if the heatshield in the muffler tunnel has gouges in it from the pinch weld. Could also be the top from over extension over negative curvatures.
Old 11-03-2012, 07:52 PM   #19
iverson03tj
iverson03tj's Avatar
That's a good point, I've been checking that area for cracks each time I look at my mounts but haven't found anything.
My trunk carpet has been out for years, so I do have easy access to it. My shocks have been in and out many times due to the stupid externally adjustable koni setup.
how come u have to take the shocks on and off? im guessing u got he Koni SA's?
PREVIOUS CARS
Old 11-05-2012, 10:12 AM   #20
dcramer
Yes, even new they aren't worth a crap on the track. What do people do with track cars ? There must be a decent aftermarket hanger ?
That being said that isn't the clunk that I am hearing I know about that one.
Dave
Old 11-06-2012, 09:56 PM   #21
Axxe
Axxe's Avatar
I am going to fill the voids on the new ones with urethane. Also I completely missed the part in your initial post about eliminating the muffler. Mine makes the weirdest noise leaving the driveway, took me a while to pinpoint.
Old 11-07-2012, 06:11 AM   #22
dcramer
Interesting. I'd like to see that and to see how well the urethane stays in.
Dave
Old 11-07-2012, 10:21 AM   #23
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
It stays in well. I've done it. Many bushings come with a wax like coating over the rubber to protect it. You'll need to use a dremel or something on low to just scuff up the rubber (inside the void) a bit, then wash the void out with some alcohol. Fill the void wait 8 - 12hrs or whatever the working time is, then install.
In the case of the e30 rear carrier mounts: The urethane in the void would form a solid 3" long chunk, the carrier mount bottom plate would prevent that from coming out even if it did come loose of the rubber.
The urethane stuff I bought is awesome, hardens up and feels like a hockey puck. Oil/gas resistant, I think it was nearly 20$ at Carquest.
Old 07-08-2013, 08:50 AM   #24
dcramer
OK, I just replaced the rear lower ball joints. I am willing to wager this is where the clunk comes from.
M3's have solid rear lower ball joints. My guess is it takes quite a bit to move them when they are partially worn. So you won't really be able to feel them until they get quite bad. But the car will be able to move them going over bumps etc.
Before you get all excited about replacing them, the bolts are likely rusted in. Mine were. What appears to be a 1 hour job is more like 4. I had to destroy the old ones to get the bolt out.
Now if you had replacement arms and you didnt mind cutting the bolt and damaging the arms it would be much quicker. Course you still have to get the inner bushing and bolt out ....
If I were dropping the subframe I'd be replacing these as a maintenance item.
