Haha i gueeeess, feels like forever though!! Just so much waiting foor parts and tools!!
Nooow im just gunna save a few bucks and get an exhaust!! Found an online store that sells all sorts of exhaust piping and flanges, i believe im gunna order all the piping from there, about 120, is the total i found, all the pipes are mandrel bent mild steel, i have the muffler and cat already, and initial tunning said the would weld it all together for 90 an hour, i plan on making it as easy as possible for them to weld it together so it takes a min. amount of time!!! Will pre cut and number each pipe in order, hopefully they can count :$
90' & 91' Imported E34 520i's, 94' E34 540i
alriiighty guys and gals!! Its all put together everything seeeems to be about right!!! take a look!!!
and for my terrible running car from the prev. video... it was all because my idle air control hose wasnt attached... rookie mistake u suppose, but concidering i am a rookie..... i could care less!.. and as for my red blow off valve.... soooon to be changing the colour
BTW it was pre warmed upppp.....
i know im not excited for the weather that coming, but my father is allowing me to keeeep my car in the garage for the winter!!!! heated and everything!!, ill be able to tweeeeeek shiiiit, and do little touch ups here and there
Ill be ordering two 90 deg. Two 45 deg , two 20 deg and 4 feet of straight pipe, i have a cat and muffler beside me.... soo if u dont mind, one day sooon ill take up ur offer and head over too mano, (manotick) crazy wat kids come up with these days....
Btw my welding skilllls SUUUUUUUUCCCCCCK sooooo any assistance would be a great help
So i drove my car! Multiple times around the block, runs beautiful at 6psi, only issue is that the idle ait control hose pops off after a couple times of boosting.... gotta figure out a sulotion for it :/ will post a driving vid soon
Epoxy will work... until the next time you try to remove the ICV. I have a piece of wire that goes around my TB and sits against the elbow to hold that fitting in.
Lol I did the same thing, only I used a ziptie instead of wire. Had mine pop out twice on me so this is a quick fix.
