Old 10-12-2012, 02:05 PM   #16
NOTORIOUS VR
NOTORIOUS VR's Avatar
Originally Posted by SiR View Post
I guess... solely for the bling factor because I doubt they would be an improvement in performance compared to the "little" boxsters.
what is the bias on your new set up?
Adding more pistons doesn't really make you stop faster, they just add modulation.
As for the bias on my setup, I would assume its around what an E46 M3 is considering it's using CSL rotors... might have to play with compounds if I feel it to be necessary though.
E36 · VEMS · TUNING
Google Talk: NOTORIOUS VR
NOTORIOUS VR is online now   Reply With Quote
Old 10-14-2012, 07:18 PM   #17
bias has a lot more to do with other things than rotor diameter. piston diameter plays a big role.....id hit up some online calcs to check it out. likely fine but id want to make sure.
you come from audi/vw world where they try to find the biggest shit possible and bolt it on . doesnt mean better braking or modulation compared to a 4 or 6 piston set up. just more bling really at the end of the day. Which is fine ..just as long as you realize that
really you can only break as hard as you have grip. if you can over come your grip easily than its doing you no good. more heat soak helps too but even oem brakes dont have that issue typically on e36 m...(i know you have a 328 baller turbo )
SiR is online now   Reply With Quote
Old 10-15-2012, 09:42 AM   #18
NOTORIOUS VR
as with most bigger/multi-piston calipers, the ones on on the 18Z and my 8 piston version are staggered in size to control pad wear.
I didn't buy my kit based on size or piston count like you seem to think. I bought it due to price and due to the stock 328i brakes being crappy.
Also for my driving style and power goals even M3 brakes will be too small. Of course the bling never hurts either
As for tire grip, I'll be rocking these:
E36 · VEMS · TUNING
Old 10-15-2012, 12:06 PM   #19
where did you grab those?
Old 10-15-2012, 12:52 PM   #20
NOTORIOUS VR
the tires?
I ordered online since Federal tires seem to be seasonal in north america.
ordered from tires-easy.ca
E36 · VEMS · TUNING
