Old 09-22-2012, 09:08 PM   #1
kadafi
Lots of tools - DeWalt, Stanley, Mastercraft etc Power drillers, rachets, Rotary etc.
Preferred method of contact anthony999@live.ca
Location - Mississauga
If you're buying under $100 worth, I will only meet in Mississauga. If you're buying over $100, I will meet at a reasonable distance.
Prices are firm but I will give you a deal if you buy multiple items.
1) SKIL 7292-01 2 Amp 1/4 Sheet Palm Sander *Brand New* $30
Product Features
Pressure control technology warns user when pressure is applied
Micro-filtration captures and contains fine dust particles
Clear vue canister removes guess work of when to empty canister
Built-in vacuum adapter - for maximum dust collection
Soft-grip design for added comfort and control
2) DeWalt D25012K 7/8" Corded Rotary Hammer Drill *BRAND NEW* $135
Dewalt D25012K Specifications:
• Amps: 6.0 Amps
• Impact Energy: 1.8 ft.-lbs.
• No Load Speed: 0-1,550 RPM
• Blows/Minute: 0-4,150 BPM
• Chipping: No
• Clutch: Yes, Factory Set
• Wood/Steel Drilling: With Adaptor
• Tool Length: 13.2"
• Tool Weight: 5.2 lbs.
Dewalt D25012K Includes:
• Rotary Hammer
• 360° Side Handle
• Heavy-Duty Kit Box
3) DeWalt 10pcs anchor kit (also fits driller above) *brand new* $25
4) Dremel Multi-Max 6300 120-volt Oscillating Kit with Free Blades *BRAND NEW* $70
I also have a dremel super accessory kit. model 709-01. 110pcs. $80 value. kit is also brand new. I will include it with the multi max for an extra $10. $20 if you want to buy acc. kit alone
PRODUCT DESCRIPTION
The Dremel Multi-Max 120-Volt Oscillating Kit is a great multitasking tool that can be used for cutting, grinding, sanding, scraping and grout removal. It is designed to offer great control and stability for more accurate cutting. If you have projects that involve repair, remodeling or restoration this could be the tool for you. Currently if you purchase the 6300-05 you will receive an additional $45 worth of blades instantly. $45 Blade Bonus(Online Only).
Blade bonus gives you 3 extra blades. Includes (MM470 flush-cut blade, MM462 bi-metal flush cut blade, and MM610 scraper blade)
Powerful 1.5 Amp motor is designed to cut through 1-1/4 in. oak door jamb
Versatile and effective multitasking tool for the DIY enthusiast as well as for pros; great for cutting, grinding, sanding, scraping and grout removal
Multi-Max features fast side-to-side motion to take on a variety of projects that involve repair, remodeling or restoration
Electronic feedback circuitry for consistent speed under load
Offers optimal control, safe operation, high precision and minimal dust
Quick-fit feature allows for faster accessory change
Separate on/off switch helps to maintain speed setting after tool is shut off
Compact design can help provide access to tight spaces
10,000 to 21,000 OPM wide speed range helps provide optimal control
Ergonomically optimized soft grip for comfort and control
Electronic feedback circuitry to help create consistent speed under load
6 ft. cord and UL listed
Note: Product may vary by store.
MFG Brand Name : Dremel
MFG Model # : 6300-05
MFG Part # : 6300-05
5) Stanley Stud Sensor 150 *BRAND NEW* 15
Detects and locates studs and joists
LED display and audio horn indicate stud edge and c-buy-and-sell-tools-hand-tools-Stanley-Stud-Sensor-150-Brand-New-W0QQAdIdZ411307436# position for accurate marking
Automatic calibration
6) Mastercraft Maximum Socket Set, 130-Pc *BRAND NEW* $160
Brand new in box. 130pcs set
same as link below
model # 58-9265-0
http://www.canadiantire.ca/AST/brows....jsp?locale=en
Socket set features high visibility laser-etched markings
Lifetime warranty (excludes carry case)
Comes with slide-in trays for tool storage units
Includes 1/4", 3/8" and 1/2"-drive ratchets and accessories
Also includes regular and deep sockets
Metric and SAE Hex Keys
kadafi is offline   Reply With Quote
Old 09-24-2012, 12:24 PM   #2
Carlos12
Carlos12's Avatar
Pm sent
Carlos12 is offline   Reply With Quote
Old 09-24-2012, 02:14 PM   #3
E30 Girl
E30 Girl's Avatar
Send a message via MSN to E30 Girl
Email Sent
E30 Girl is offline   Reply With Quote
Old 09-24-2012, 03:31 PM   #4
Shuks
Shuks's Avatar
Interested in #2, #4 with accessory kit and #6. PM me with price.
Shuks is offline   Reply With Quote
Old 09-25-2012, 01:39 AM   #5
kadafi
^^^ Pm's/emails sent
Old 09-30-2012, 09:30 PM   #6
kadafi
Dewalt Driller + Dremel 6300 SOLD
