I kind of get doing some emblems if you want to be able to peel it off after but otherwise...ugh. No reason to cover a clean car it that crap, just another step towards stupidity.
__________________ BIMMER HEAVEN
Not too sure what you mean...Painted right on top, no special prep. Still can be taken off at anytime without damage.
how hard is it to keep clean and how do you wash it Phil?
Better then any "normal" paint job, but like any black it has to cleaned on regular basis. I use a 2500psi pressure washer on it with no issues at all, as long as you dont put it right next to the surface! Soap or degreaser works well...
I've used it on my old wheels and had the tires unmounted/remounted twice without it coming off (new tire machines are awesome). Strong as hell, but make sure you use a lot of it on application as it needs to be thick for proper removal. If it's too thin, you'll be forever picking it with your fingernails. As an example, I used 1-spray can per wheel. Get it at your local Home Hardware store.
German Mechanics
2530 Speers Rd #5
Oakville, ON Canada
(905) 286-4362
Mon-Fri 9am - 5pm www.GermanMechanics.ca
