Go Back   maXbimmer Forums > Classifieds > For Sale > Drivetrain, Engines & Transmissions
Old 09-16-2012, 10:57 AM   #1
dcramer
FS M3 3.32 LSD Diff
115K miles out of my M3
Great upgrade for a 328, put one in my vert, it provides you with an effective 20HP. Cheapest, most reliable 20HP you can but for a 328.
No issues with it, upgraded my diff.
450 OBO.
Old 09-16-2012, 05:32 PM   #2
Differentials dont add horsepower dude...
And are you sure you don't mean 3.23? 3.32 doesn't exist.
Old 09-16-2012, 05:53 PM   #3
dcramer
Yes, it is a 3.32, thanks for noticing.
And I said effective HP.
Old 09-16-2012, 06:26 PM   #4
No such thing as a 3.32. And can you explain effective horsepower? Never heard of such a thing.
Old 09-16-2012, 06:55 PM   #5
dcramer
Crap, apparently I can't type worth shit. It is a 3.23 as you pointed out.
effective HP is defined here
http://www.merriam-webster.com/dicti...e%20horsepower
Technically increasing the diff ratio increases torque at the wheels, however
Since HP = (torque * rpm)/5252 if you increase torque then you increase HP
Thanks for catching my typos
Dave
Old 09-16-2012, 11:31 PM   #6
dave.a.cote
Buddy, your math is wrong. Sure a higher ratio will put more torque to the wheels but it will also happen at a lower tire rpm so your power remains constant.
dave.a.cote is offline   Reply With Quote
Old 09-17-2012, 09:05 AM   #7
dcramer
Ok, remember I said effective power. I am not suggesting that a higher ratio diff increases actual engine HP.
What does happen is that the higher ratio increases torque at the wheels for a given engine RPM.
The bottom line is that your 328 will pull better, now you will lose top end, but any top end you lose would be illegal here so all in all it's a great upgrade, and it's relatively cheap.
Old 09-17-2012, 11:05 AM   #8
Dinanstu
Either way, its a good diff for a 328.
Old 09-20-2012, 11:08 PM   #9
Mike e39
Mike e39's Avatar
just so we have strait. different gearing same HP. here is example :
Mike e39 is offline   Reply With Quote
Old 09-21-2012, 08:54 AM   #10
Dinanstu
Wow a graph!
I know what dcramer meant, give it a rest. Gear ratios actually make a difference in performance...If it didn't, they would all be the same...
Old 09-21-2012, 08:56 AM   #11
dcramer
Actually it's all good, this is like free advertising. Saves me from ttt every day
Old 09-21-2012, 09:06 AM   #12
Blades
Your opinion is to long
Blades's Avatar
lol .. thats from a motorcycle .. you can't compare that type of ratio to a cars differential .. apples and oranges.
-=[ BL/\DES ]=-
Old 09-21-2012, 09:07 AM   #13
dcramer
And why not ? Do motorcycles have different laws of physics ?
Old 09-21-2012, 09:50 AM   #14
Blades
Blades's Avatar
Do they have a pinon gear/shaft? and as for physics does a GSXR have one type of force that needs to be converted/switched to another type of motion?
-=[ BL/\DES ]=-
Old 09-21-2012, 09:54 AM   #15
dcramer
Some of them do, yes. BMW's , Honda's to name a few. And what difference does it make if you are changing the rotational vector? It's still torque and ratio's
Can you back this assertion up with some math ?
Dave
