Old 09-06-2012, 01:36 PM   #1
BMe30
all by chance...
BMe30's Avatar
Brake squeak after awesome ddt at bimmercruise
Well pretty much after the awesome lapping events on the way home noticed some squeaking from the brakes.. It was pretty bad the next day but noticed it was slowly going away... Still there at times.. Did they glaze over a bit?
Hawk hps
Brembo blanks
600*F brake fluid
All new since spring
Gone but not forgotten
Old 09-06-2012, 01:38 PM   #2
E30 Girl
E30 Girl's Avatar
Send a message via MSN to E30 Girl
Probably just brake dust have you power washed the car and brakes since?
E30 Girl is offline   Reply With Quote
Old 09-06-2012, 01:47 PM   #3
BMe30
all by chance...
BMe30's Avatar
Nope... Didnt even wash the car since lol
Ill give it a shot tonight
Old 09-06-2012, 01:53 PM   #4
That happens to me once in a while, I usually do a brake service and it goes away.
Old 09-06-2012, 01:55 PM   #5
E30 Girl
E30 Girl's Avatar
I always get brake squeak after the track or if I haven't washed the car in a while it's pretty normal when you have a more serious pad. After a good wash it goes away.
Old 09-06-2012, 02:08 PM   #6
SiR
Vtec just kicked in
hps can squeak from time to time.
try the hp+ for more dust and daily squeal.
Dont sweat it. A little squeal never hurt anyone
-||Old Crayons||-
Old 09-06-2012, 02:10 PM   #7
Robb
EX E30 M3 Owner
Robb's Avatar
The rotors are glazed with brake residue.
Get a brake service done to clean them or machine them depending on how thick the rotors are. Also could be an intermittent sticky caliper, so you best service the calipers as well.
I use HP+ and when braking, they squeal like a girls first time !
Old 09-06-2012, 02:45 PM   #8
BMe30
all by chance...
BMe30's Avatar
Lmao
Thanks all!
Old 09-06-2012, 04:13 PM   #9
Have you tried going out and doing a few heavy braking events without coming to a stop to get the glaze off?
I have HP+ on my car and the squeal isn't that bad. It only happens if I'm dragging the brakes at low speed, but even then they aren't outrageously loud.
I just picked up a set of HPS pads to use on the street so I can save the HP+ for the track and mainly because the HP+ dusts like a muthafuka and the dust is hard to clean off the rims if you leave it for too long.
Old 09-06-2012, 04:18 PM   #10
InfiniteDice
14 Years with the E30
InfiniteDice's Avatar
Sometimes squeaks can be the discs not being grabbed well enough by the calipers. Maybe you overheated a caliper and now it's seizing. I'd take the caliper off the mounting bracket and lube up the sliders. Check the boot around the piston for cracks or signs of rust.
