Help! 92 325i running problem
First Post, first BMW
I bought the car a couple days ago, not cerftified, as is.
Ran fine on a test drive and on the way home, until it got to operating temp. Once the car is warmed up and you accelerate, at roughly 2000 rpm it stutters and losses power but never cuts out, then quickly comes back. If you acclerate slowly it doesn't reoccur but if you try to accelerate at a normal rate it will sputter again. If it is cool it goes no problem.
OBD code shows 1444 (no faults found)
(on another note the system repeats the code over and over and over again, is it not suppossed to do the code once and end with the 1000 code?)
Any suggestions? TPS? Mass Air Flow Sensor? Fuel Pump?
Thanks for the help
