Old 08-06-2012, 12:15 PM   #1
syedali
Exclamation Urgent - Need mechanic today - Mon Aug 06 - Any recommendations?
Two weeks ago, my car (2004 325i) won't start on my way back from grocery shopping. Stuck in middle of grocery parking, I had it towed to the nearest mechanic, who said he specializes in Audi, BMW, and Mercedes. He said its the starter, kept the car for a day and replaced that.
It ran for a week and then exact same thing happened to me where it wont crank.
I pushed the car a little, popped the clutch, and drove immediately to the same mechanic as I believe he owed me for the crappy work he had done.
This time he said its the fuel pump and had me change that.
Lo and behold 1 week after replacing my fuel pump I am stuck again with same problem !!
Is there anyone reliable open today that I can take the car to. I have already taken too much time off work to deal with the car issue and cant really afford to take more days off.
syedali is offline   Reply With Quote
Old 08-06-2012, 12:28 PM   #2
I doubt anyone is open today. What shop did you take it to twice? Check the positive terminal inthe engine bay. I had a similar issue once on my car and it was a badly corroded power terminal preventing the start up.
Old 08-06-2012, 01:12 PM   #3
syedali
Checked everything I can think off Maybe I can just tow it to Rocco at RMP, and hope he can work on it first thing tomorrow. Wish I can get in touch with him some how - his shop is closed today.
Old 08-06-2012, 01:45 PM   #4
noid
noid's Avatar
If you can bump start it, my guess would be that it is electrical. Specifically it could be the ground that the starter uses. I had a similar problem with my E30 a few years back.
http://www.rtsauto.com/ground-cable-...-preventative/
Use jumper cables to recreate an alternative ground and see if it fixes your problem.
Old 08-06-2012, 01:54 PM   #5
Ground cable between right side engine mount and frame rail!
Old 08-06-2012, 01:58 PM   #6
syedali
Ah...any pics / diy anywhere :S Is this under the car or can i access it under the hood ?
