Old 06-12-2012, 01:28 AM   #1
adam325i
adam325i's Avatar
Darla cranks my engine....another M50 build
Haters please find somewhere else to go. If you have constructive criticism, Ill listen to it. Ive done lots of research before Ive started this, but if you have some hints and tips please share!
Thanks for looking!
Starting off with a 1990 325i 2dr
Unbolted a dirty ole rear subframe
Taken down to bare metal, sway bar reinforcements and Toe/Camber plates welded in place, Epoxy primed.
Painted with 75D Poly subframe and trailing arm bushings
Engine bay looks dirty old and tired.
Out with the old
To prepare with the new.....ish M50tu25
Engine bay degreased. Deleting Washer fluid, power steering, A/C, ABS. Going to cut the wires out that arn't needed anymore and tuck it through the fender. Also be doing a slight shave on the bay and stich up the front end.
Front subframe and ect taken out. Will be getting the same treatment as the rear. Have a e36 M3 rack to go in along with new bushing control arms, ball joints, tie rods etc. engine mount reinforcements
Im currently pulling all the seam sealer out and the carpet out to clean up some rust thats starting.
Project will be on hold for abit as I aquired another e30 I need to do some work on to move to the back yard as driveway space is getting limited as well garage is full. Need to finish up a turbo mk2 supra then work will start on this again.
90 325i 4dr Winter fun
90 325i 2dr Summer/track car
87 325i 4dr Parts
adam325i is online now   Reply With Quote
Old 06-12-2012, 11:02 AM   #2
Why you think people will hate? Lol it looks great IMO!
Keep up the good work! Have everything planned out swap-wise it looks like, but is anything still up in the air?
cormier is online now   Reply With Quote
Old 06-12-2012, 11:07 AM   #3
El Gato Liso
El Gato Liso's Avatar
you have the plastic thermostat housing on the m50. take that junk off and put a metal one on! its a cheap upgrade!!
Old 06-12-2012, 12:17 PM   #4
Yeh, that will crack pretty quick.
I'm gunna be hatin' because there are now too many M50 swapped E30s around. Makes me feel less good about myself.
Jokes jokes, looks good.
Old 06-12-2012, 01:21 PM   #5
adam325i
adam325i's Avatar
Thanks for the kind words. That picture of the engine was right after i got it from the junk yard. Got it out of a E34 that was in a front end collision so the plastic thermostat housing was cracked anyways.
Ordered a nice list from pelican parts. FYI for anybody that orders there housing it comes with a gasket even tho it doesn't say.
Engine will have new rear main seal, water pump, pan gasket, valve cover gasket, ebay headers but I bought the long tube ones. I hear they will work but some persuasion will have to be used.
As for the brake booster I plan on moving it over .5'' and weld half a clevis on the existing clevis so the pedal and rod wont bind. I've heard it will and wont work so ill try it since its free and if it doesn't ill get another booster.
Maxbell you should start hatin somemore because I have TRM c1's aswell but in black and love them!
87 325i 4dr Parts
Old 06-12-2012, 04:21 PM   #6
matty.dc
matty.dc's Avatar
Thats why you have to swap in an OBDI S52 (thread to follow)
2012 Hyundai Veloster Tech- Daily Driver
Old 06-12-2012, 04:32 PM   #7
adam325i
adam325i's Avatar
This is going to be a build to follow! I've seen the parts so far and getting excited for him lol
87 325i 4dr Parts
Old 06-12-2012, 07:49 PM   #8
JUICY J CAN'T
propr'one's Avatar
nice project. Why are you deleting the windshield washer? Dedicated track car?
hid headlights
Old 06-12-2012, 07:56 PM   #9
adam325i
adam325i's Avatar
The car will only be used in the summer for track and road. Washer pumps arnt kind to me and just have problems with them. Never had it in my daily e30. Just in the winter sucks lol.
87 325i 4dr Parts
Old 06-13-2012, 04:12 AM   #10
adam325i
adam325i's Avatar
Thanks! Im reading thru your build thread. Amazing work! I see that you used an automatic engine harness.
The harness that I have is auto aswell. What wires and stuff do I need to remove to make it work? Anything would be great help!
87 325i 4dr Parts
Old 06-13-2012, 06:19 AM   #11
There's not really much you have to remove for the auto harness to work. Here's the start of my questions from my build thread.
http://www.r3vlimited.com/board/showthread.php?t=231332
Old 06-13-2012, 08:23 AM   #12
El Gato Liso
i used an auto harness. i didnt remove anything! what i did was chop off the diagnostics port by mistake thinking it was for the transmission...but i just have to find time to resolder that back on lol
Old 06-13-2012, 01:44 PM   #13
adam325i
adam325i's Avatar
Thanks guys! I'll end up cutting whatever's not needed with the engine harness. I've got a spare just in case.
87 325i 4dr Parts
Old 08-01-2012, 12:43 AM   #14
adam325i
adam325i's Avatar
Not much progress has been made due to flooding in the basement and got rear-ended and have a sore back and neck.
Sitting on the computer looking around and found something i was interested in.
I present to you a M54b30 crankshaft and head and block!
Block sitting on the ground and its new home right above it.
If anybody is throwing out a non vanos m50 camshaft, id be happy to take it off your hands, if not ill just grab one out of the junk yard.
If you have any knowledge of this m50 stroker s50 clone engine, please let me know. Thats all for now!
87 325i 4dr Parts
Old 08-01-2012, 01:20 AM   #15
El Gato Liso
hey adam ill take a look for the stuff this weekend. been so busy with a lot.
also, i have the m50 cams exhaust and intake, but from a vanos. i'll take it you need just the intake cam?
