Old 07-20-2008, 07:49 AM   #1
Oakvillez3
will tire fit rim?
does anyone know if a 245/40/17 tire will fit a 7.5" rim? thanks
Oakvillez3 is offline   Reply With Quote
Old 07-21-2008, 04:42 PM   #2
Mickey Knox
doubtful, i have 235's on 8 inch wheels and they are just flush
Old 07-22-2008, 12:13 PM   #3
Way past the recommended range. Don't do it.
Old 08-01-2008, 06:18 AM   #4
Oakvillez3
what is the recommeded range for a 7.5" rim?
Old 08-01-2008, 10:32 AM   #5
205-225. 235 is the furtherest you should push it.
Old 07-19-2012, 12:47 PM   #6
zaatri
i say pass the recommended range because you need a grip, i have 8.5 and i fit 275 on them
zaatri is offline   Reply With Quote
Old 07-19-2012, 01:06 PM   #7
It wont handle well, unless it's going on the back of a muscle car, I wouldn't do it.
You are better off buying better rubber than trying to fit fat tires on skinny rims.
Dare I squeeze
Old 07-19-2012, 01:21 PM   #8
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
I had 225's on a 6" rim, but they were stiff r-comps. Feels like shit and transitions are a sloppy mess as the wheel moves from one sidewall edge to the other. Gripped like crazy though.
Old 07-20-2012, 08:47 PM   #9
crxgsr
BMW
Okay guys, please have references to backup your claims.
In the Pirelli Tire Guide book, 7.5" rim is permitted for 245/40/17. Nominal would be 8" to 9.5"
Old 07-26-2012, 03:01 PM   #10
jay01_brown
OBSERVE
what about a 255/40 on an 8.5 rim?
jay01_brown is offline   Reply With Quote
Old 07-26-2012, 05:12 PM   #11
Dinanstu
http://www.tirerack.com/tires/tirete...jsp?techid=199
Need an s54 MZ3 coupe...will trade...
Old 07-26-2012, 05:31 PM   #12
Dinanstu
Cant edit my post, so here read this article at tire rack.
http://www.tirerack.com/tires/tirete...jsp?techid=198
It depends on the tire itself and what rim it was designed to fit because of the steel belts.
Look up that tire on tire rack and see what wheels are recommended.
Old 07-27-2012, 04:25 AM   #13
Axxe
Axxe's Avatar
^yeah, if you are running a narrow 245 you might be able to sneak it by, but it's going to look like it belongs on MrT's van.
Old 08-01-2012, 07:49 AM   #14
m_guimont323
Can the tire shop mount it ? Probably...
Will you enjoy driving your car.... not likely. You might as well mount a set of 65 series winters on the car if you're going to put a tire like that on a 7.5" rim.
m_guimont323 is offline   Reply With Quote
Old 08-01-2012, 09:01 AM   #15
crxgsr
BMW
So you're telling me that when you are driving, you can actually feel a difference between driving on a 7.5" rim and a 8" rim? please explain what the difference in feeling will be.
