Old 06-23-2012, 09:59 PM   #16
God damn, those Meister's are so much win. Congrats man.
Old 06-24-2012, 12:47 AM   #17
MPRESIV3
M Powered
Muthaphuckin MEISTERS S1!!! My all time fave wheels.
Need to get myself a set.
I was checking them up real close last at the pre-meet last night before the midnight cruise.
BTW - is the vinyl suppose to fade like that?
Instagram: @ellicktrifying
'04 ///M3 LSB on LSB
MPRESIV3 is offline   Reply With Quote
Old 06-24-2012, 10:40 AM   #18
Not sure, must vinyl jobs I've seen have always been black or white, I'm sure the more expensive stuff doesn't fade as bad.
Old 06-25-2012, 12:25 PM   #19
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
What are the specs on the meisters and tires? Looks like you can go down a shitload all around.
Old 06-25-2012, 12:27 PM   #20
kevin325
AMG ETR
kevin325's Avatar
Looks better now IMO!
kevin325 is offline   Reply With Quote
Old 06-25-2012, 01:15 PM   #21
18''x9'' Squared
et30
Currently have a 10mm spacer in the front, none in the back, might add a 5mm.
235/35/18 tires all around
It will come down slightly, I don't know about a shitload. Last year I was rubbing rim in the rear and I don't want to mess up the pretty lips...
I'm running out of travel in the front, almost tempted to buy some BC Racing coils so I can slam it more and sell my current ones.
2 More:
Old 06-25-2012, 01:23 PM   #22
Front can easily go down another inch
Old 06-25-2012, 01:36 PM   #23
There is definitely room to go lower, I'm not worried about that. There is only about an inch of travel left, i'd be riding on bump stops if I lowered it that much...
The damn 96+ mounts are so huge, taking up alot of travel. Camber plates would fix that, but I'm not sure I wanna spend the money since i probably wont keep the car past next year.
Old 06-25-2012, 08:03 PM   #24
Axxe
Axxe's Avatar
Nice! Nice offsets, works out perfect. Haven't had a ride in a BC-racing equipped car, should be similar to my TRM setup.
Old 06-25-2012, 09:07 PM   #25
R.S.C
Imaginary Player
R.S.C's Avatar
Nice. I was wondering who's car that was at the cruise. Colour although unintended, looks good.
Yamaha R6 + Alpine White F30 + Techno Violet e36
R.S.C is offline   Reply With Quote
Old 06-25-2012, 09:36 PM   #26
Yea I think your TRMs are similar I like how the height is adjustable that's what I need right now to go lower.
Yea that was me it had a few people doing double takes. Before I posted about the wrap a few friends asked if I bought another car.
Old 06-25-2012, 09:59 PM   #27
Axxe
Axxe's Avatar
^ If you want a ride I will try to make it out to one of the meets. Will give you perspective on my astronomical rates.
Old 06-26-2012, 10:25 AM   #28
Sounds good, give me a heads up and i'll try to make it.
About 1/2'' lower in the front, probably still needs to come down a bit more.
Old 08-07-2012, 09:08 AM   #29
A bit lower in the front now and 5mm spacers added to the rears.
Old 08-07-2012, 10:09 AM   #30
That 5mm spacer made a big difference. Car is finally sitting perfect!
