Old 06-14-2012, 09:47 AM   #1
Torontoe36
Rubbing of tires
Hi I purchased a BMW 325i 2001, have an issue with rubbing on my rear passenger side. The car is lowered. My current tire configuration is
Front: 225/40/R18
Rear: 255/35/R18
Without changing shocks, or rolling fenders I am thinking of going with this configuration of tires:
Front: 225/40/R18
Rear: 235/35/R18
any comments, suggestions?
Thanks,
Cheers
Torontoe36 is offline   Reply With Quote
Old 06-14-2012, 09:59 AM   #2
Big Chin
I would just by a 10mm spacer.. but then again depends on how bad the rub is...
Maxbimmer FeedBack
Big Chin is offline   Reply With Quote
Old 06-15-2012, 07:03 AM   #3
Dinanstu
You didn't mention the wheels...
What are the wheel diam's and offsets?
Old 06-15-2012, 09:04 AM   #4
You need this: http://www.maxbimmer.com/forums/showthread.php?t=151048
Old 06-15-2012, 09:20 AM   #5
Michel
Michel's Avatar
Spacers will make the rubbing MUCH worse. Do not do this!
Just get the thinner tires, you should be fine.
Michel is offline   Reply With Quote
Old 06-15-2012, 09:28 AM   #6
Blades
Your opinion is to long
Blades's Avatar
what? LOL
-=[ BL/\DES ]=-
Old 06-15-2012, 09:29 AM   #7
Blades
Blades's Avatar
Front: 225/40/R18
Rear: 255/35/R18
Front: 225/40/R18
Rear: 235/35/R18
Thanks,
Cheers
That would be your best bet. I would try to fit anything over 245 on a E46 .. 235 would probably be best.
-=[ BL/\DES ]=-
Old 06-15-2012, 04:48 PM   #8
///M_AMAZIN
///M_AMAZIN's Avatar
+1 I have the same issue... Rubbing on the rear right side
I might get them rolled sometime soon as that is my only option since i have 235's with 10mm spacers in the back
SANI
@IAMFNAMAZIN
///M_AMAZIN is offline   Reply With Quote
Old 06-18-2012, 02:49 PM   #9
crxgsr
BMW
The 235/35/18 will be smaller than the 225/40/18 in terms of height. I would suggest you just go with 225/40/18 all the way around.
Old 07-06-2012, 01:52 PM   #10
Torontoe36
just to close the matter, got new vredestein 225/40 and 235/40 tires and the rubbing doesnt occur anymore there is just enough spacing for when the car drops..
Old 07-06-2012, 02:41 PM   #11
Just put one of these on your car and the fat chicks will stop asking for rides..
Old 12-26-2012, 03:11 PM   #12
505hp
Can you check and make sure the spring isn't broken on that side?
www.limitlessauto.com
505hp is offline   Reply With Quote
Old 12-26-2012, 06:06 PM   #13
thomase30
thomase30's Avatar
Is it springs or coilovers
thomase30 is offline   Reply With Quote
Old 12-26-2012, 07:54 PM   #14
Torontoe36
the spring is chipped on the side now in process of looking for replacements
