Old 04-19-2012, 06:45 AM   #46
defaultName
Have you looked into using Euro S50 ITB's on an M42?
I'm assuming it would be a cost/availability issue to go this route but it could be easier.
Just wondering if you know anything about this set up?
Old 04-19-2012, 06:59 AM   #47
BMe30
all by chance...
BMe30's Avatar
Originally Posted by SamE30e View Post
I stand by my statement. I would get a manifold fab'd up. Might see a bit better gain.
There is a chance i may have to... But ill know for sure when i start putting it together.. But i still want to kerp long runneres to help with my tq curve
Default name... I have heard and seen that on some threads.... They are very costly.... Imo motorcycle itbs are cost effective. The first set of itbs shipped to my door was around $120 i think... These $180... Those euro bmw ones when i was looking well above $400
Gone but not forgotten
Old 06-03-2012, 03:44 PM   #48
BMe30
all by chance...
BMe30's Avatar
well it took some time but a friend of mine was able to squeeze in some time for me at his shop to do this...
next up.. to make the two units one again.. fill the holes...
been a little busy with some other things so the next few steps may be a while... but not as long as this update was.
Old 06-03-2012, 07:37 PM   #49
mr ilia
Any pics as how the TB connection looks inside af the joint?
2004 BMW 325i, sedan, 5spd.
Old 06-03-2012, 07:41 PM   #50
BMe30
all by chance...
BMe30's Avatar
Not yet i still have to knife edge the manifold.. When i start that youll see the pics
Old 06-05-2012, 09:13 PM   #51
Nice work at the shop -- looking great dude!
Old 06-05-2012, 10:40 PM   #52
BMe30
all by chance...
BMe30's Avatar
Thanks but all i did was look at my buddy program the machine and look in awwwe lol
Im pretty stoked about this... There are a few changes from the initial plan due to more important items happening in my life... But she will breathe for bimmercruise!
Old 06-06-2012, 03:33 PM   #53
Any plans on adding an adjustable fuel pressure regulator and a WB O2 sensor to help tweak the fueling in the mean time? Eventually you will need to go standalone though...
Old 06-06-2012, 07:24 PM   #54
BMe30
all by chance...
BMe30's Avatar
well... not sure if i need a fpr... i was told it will be fine along with the stock injectors.
Old 06-06-2012, 07:31 PM   #55
Maybe, but I'd still consider installing a WB O2 though so you can see how the DME adjusts and keep an eye on things.
Old 06-06-2012, 07:36 PM   #56
BMe30
all by chance...
BMe30's Avatar
help me install it?
Old 06-06-2012, 11:06 PM   #57
help me install it?
I can give you a hand if you'd like. It's pretty straight forward. I installed one in mine before I started fooling around with the M30 AFM and 19lb injectors. And two years later it's going to come in handy for tuning my 2.8L stroker which will be running stand alone
Old 06-22-2012, 07:56 PM   #58
BMe30
all by chance...
BMe30's Avatar
ok so after work i started to knife edge the modified upper intake
here it is before i started
after a grinding session
then i started on spacing the itbs
and here is what it looks like through the opening
engine to filter
filter to engine
more to come!
Old 06-25-2012, 10:13 AM   #59
BMe30
all by chance...
BMe30's Avatar
Little update...
So i made the tab extension to connect the butterfly rods together. I used rivets and it works... But i did notice some play. So i brought the unit into work today to see if the welder can fix it. Ill pOst some pics when i can...
After this im going to work on plugging the holes and setting up for the secondary vac log for the valve cover vent. Later on that will have an oil catch can. After thats done going to work on the fiberglass plenum
Old 06-25-2012, 12:36 PM   #60
Woofer
Woofer's Avatar
Sweet work Bruno!
Can't wait to hear it.
Still want a rematch LOL
