Old 04-25-2012, 10:18 AM   #1
Klipzs
car was about to die in the middle of the intersection
On my way driving to the train station, I stopped at a traffic light to make a turn. I then realize that the car started vibrating slightly and that was due to rough rpm ( about 500rpm). The battery light then started flickering. If I haven't given the car gas during the intersection, the car probably would have stalled. Car seems fine at normal speed but when driving slow(5-20km per hour) this happens.
What could possibly be the problem?
Klipzs is offline   Reply With Quote
Old 04-25-2012, 11:18 AM   #2
slemmer
Driving in the fast lane
slemmer's Avatar
Dirty o2 sensors?
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
Old 04-25-2012, 01:50 PM   #3
e30drifter
SLYDWAYZ
e30drifter's Avatar
Alternator
http://youtube.com/watch?v=JUpYp5eqTbk-(GO NUTS FOR DONUTS)
"if you think education is difficult, you should try being stupid"
e30drifter is offline   Reply With Quote
Old 04-25-2012, 01:52 PM   #4
Klipzs
Alernator is a bosche brand and was replaced a year and a half ago.
Old 04-25-2012, 02:25 PM   #5
Vacume leaks or alternator. Most othe problems will just cause a check engine, run in limp mode, but not actually stall.
Old 04-25-2012, 03:31 PM   #6
Klipzs
Will I have a small evap light last time I checked. I'm not sure this problem could be.
Old 05-02-2012, 02:38 AM   #7
Klipzs
Ok so I got my codes scanned and got P0442 and P1250.
P0442 is the small evap light my mechanic was talking about.
But what about P1250? Someone mentioned that P1250 was the fuel filter but what fuel filter cause my battery light to flicker when my car was about to die?
Old 05-04-2012, 10:28 PM   #8
BmW1819
light came on cause car almost stalled
Old 05-04-2012, 11:01 PM   #9
When car goes under normal idle (almost die) its normal for the battery light to come on (not charging enaugh)....Fuel filter can NOT have its own code, as it has no electronics to it, its just a physical part that separates dirt from gas!
Old 05-04-2012, 11:19 PM   #10
BmW1819
Bingo euro style
could be alot of things
Old 05-04-2012, 11:24 PM   #11
Oyster
Send a message via MSN to Oyster
happened to me, it was the MAF!
Oyster is offline   Reply With Quote
Old 05-04-2012, 11:31 PM   #12
Yes, i think the 1250 sounds familiar when i had to replace my MAF 2 years ago...
Or it was general missfire!
Old 05-28-2012, 11:49 PM   #13
Klipzs
Hey guys i appreciate the help.
My peake tool finally arrived and I did a scan and came up with these codes:
80 : EWS Signal
91 : EVAP small leak detected
dE : Coolant temp too low for closed loop operation
The small evap leak is not new to me, but the EWS Signal and the "Coolant temp too low for closed loop operation" are things I have never heard of.
Any idea what could be the problem?
Old 05-29-2012, 06:46 AM   #14
sproule905
sproule905's Avatar
Tstat and sensor. Good luck
Old 06-02-2012, 04:26 PM   #15
Klipzs
Thank you. noob question but which sensor do you think i would need to replace?
